Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 07-17-2012, 09:40 AM
lakinghorn's Avatar
lakinghorn lakinghorn is offline
Vehicle: 2012 Ram 1500 crew
Trim Level: Outdoorsman
Color: Sagebrush Pearlcoat
lakinghorn is on a distinguished road
Default who is using synthetic oil?
I just bought a 2012 ram 1500 crew outdoorsman with a hemi. Ive been doing some research and talking to customers who have switched vehicles, not necessarily trucks over to synthetic after the first oil change with varying results.
A good customer of mine just bought there fifth grand cherokee all of which he ran full synthetic in and hadnt had a single issue in any of them, as well as getting 1 to 2 mpg better then anyone else ive talked to that doesnt run synthetic.
From what ive read these are the benefits for me to go to synthetic:
works better at higher elevations (live in the black hills of south dakota)
quicker warm up for short trips ( i have about a five minute drive to work)
better where temp fluctuates alot ( wego from -30 degrees to 115 yearly)
Im pretty sure im going to do it because it sounds like a real benefit to me personally but would like to hear from some of you running it and seeing what you think. Obviuosly if they put it in SRT stuff from the factory theres a reason performance wise.
My other question is what to go with as far as brand. i always ran mobil with my old truck and had great luck. switched to penzoil when i started working at the dealership and had lifters start knocking until i added lucas oil stablilizer. Im thinking ill go back and use Mobil 1 synthetic but if the penzoil synthetic is working good it would be easier.
Just curious what your guys experience is and what your using since this synthetic thing is all new to me. Thanks in advance!
Old 07-17-2012, 10:10 AM
Rep:1797
On my first oil change, I switched to Synthetic.
I noticed the difference in the way in drove....Im sure it wasn't just me, because it was noticeable.
It seemed to drive smoother, a little bit more responsive (this may just be me), it didnt struggle like it did on regular oil (hard to explain the last one)
I am now almost due on my 2nd oil change
Old 07-17-2012, 10:19 AM
DClig10 DClig10 is offline
Vehicle: 2009 Dodge Ram
DClig10 is on a distinguished road
Guys does it matter when you switch to the synthetic? I just bought an 09 Ram with 40k on it and wanted to make the switch, but am unsure if would harm anything since it has run on regular for so long....
Old 07-17-2012, 10:39 AM
Rep:1797
Im not a mechanic but I do not think it matters.
I would get a flush first before putting synthetic in....that is what I would do
Old 07-17-2012, 10:41 AM
I push the skinny pedal
Rep:3277
Since the factory oil is a full grade III synthetic, everyone can say they have been using it. Mobil 1 is what comes in the HEMI engines from the factory, and it's the prefered oil, even states that on the SRT8 oil caps. I'm a fan of the Grade IV synthetics like Mobil 1, Amsoil, Royal Purple. Amsoil is the better of the gIV's, however it can be a real pain to get a hold of on short notice as it's almost entierly through their online store or you know a local private supplier. RP is overpriced, but it's what I use since I can pick it up by the case from my local speed shop, and M1 can be had from most parts stores.
Use synthetic from your first oil change, you won't hurt a thing with the tight tollerance of these engines and they have already been factory run for break in.
Kurtis
Old 07-17-2012, 10:57 AM
Asur Asur is offline
Vehicle: .
Rep:4373
On my first oil change, I switched to Synthetic also, mobil1 full synthetic. Had the same stuff in my 2001 Grand Cherokee, never had an issue in 12 years of driving it.
will change my oil every in around 6000k but picked up an oil test kit to have it Analyzed then will see how long I stretch the next one.
Old 07-17-2012, 10:59 AM
Rep:1797
Thanks for the info!
But what synthetic oil would you recommend that is easy to obtain/over the counter type oil?
Castrol? Mobile one as you indicated above?
Old 07-17-2012, 11:01 AM
Rep:1797
Oil Test kit?
Where did you grab this from and what brand is it so that I can look it up?
What grade is recommended in our trucks again?
10W20 for the Hemi with MDS?
Old 07-17-2012, 11:03 AM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
I had my 1st oil change yesterday and I got mobile1 full synthetic. Yes its much more expensive but it makes me feel better...and I think it drove smoother too
MATT
Old 07-17-2012, 11:13 AM
lakinghorn's Avatar
does anyone have any evidence to show in increase in gas mileage that im hearing from alot of people?
It would make sense, better lubrication, less friction, more effiecient would make the gas burn better two and get more in the engine. im really not seeing any reason from anyone not to go to it.
