View Poll Results: Who makes the Best???
Circle D 19 55.88%
Edge 11 32.35%
TCI 1 2.94%
ATS 2 5.88%
Other 2 5.88%
Multiple Choice Poll. Voters: 34. You may not vote on this poll
Old 08-20-2012, 09:21 PM
SilentService SilentService is offline
Vehicle: 2012 Dodge Ram
Trim Level: 1500 Crewcab
Rep:49
SilentService is on a distinguished road
Originally Posted by HEMI450HP View Post
I would stick with a 3000. Any higher is going to bring you out of your powerband too soon, and is going to build more heat. I wouldnt go higher than 3000 unless you have plans to go with a cam that raises your powerband to a higher rpm.
Im planning to get cam yes, Im looking at spartan cam, mufflex 18" and an E-cut out to go with this, all in one whack
Old 08-20-2012, 09:49 PM
HEMI450HP HEMI450HP is offline
Vehicle: 2010 Dodge Ram 2500
Rep:69
HEMI450HP will become famous soon enough
Awesome. Its going to feel like a completely different truck. I wouldnt go over 3200 though so that you can keep the computer happy. These trucks start to act finicky when you start going higher than 3200.
Old 08-21-2012, 12:10 AM
Rep:49
Ill keep it in mine when getting everything paid for, Ill be going with edge after reading this poll, should I get pro or the other one?
Old 08-21-2012, 12:15 AM
Rep:69
The Pro Billet is overkill for most trucks. I only recommend that converter to the guys with built motors, or those running alot of boost or spray.
The billet 11" is more than enough.
Old 08-21-2012, 01:25 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Cam, heads, 125hp shot with 4.10 gears???
Old 08-21-2012, 01:29 PM
Rep:69
Even then, I would still be confident in the billet 11". Only real reason I see to go with the 9.5" is if you want to run higher than say a 3600 stall. I used to run a 9.5" 3600 stall in my 03, and it was great. I also ran the billet 11" wit the exact same mods, and it held up just fine as well. No point in spending more than you have to in order to get the job done. Over the past 7 or 8 years, I can count the number of converter failures on 1 hand with the 11" converters.
Old 08-21-2012, 01:32 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Also, typically with a smaller diameter converter you get more loss in power to the wheels. That sort of goes hand in hand with higher stall rpm.
Sean
Old 08-21-2012, 06:39 PM
916Timmy's Avatar
Rep:1443
I like cheaper...when it works!
Old 08-21-2012, 10:59 PM
Redhemi03 Redhemi03 is offline
Vehicle: 2003 hemi ram
Trim Level: Slt
Color: Flame red
Rep:26
Redhemi03 is on a distinguished road
Watch out with the spartan cam, I have a few guys that's said that cam really didn't perform, I would prolly do a sidewinder or hellfire cam, a lot of ppl are happy with that and comp 268's! I run a sidewinder with a edge 2800 and I'm running 8.70 in 3000 da, this winter I should be down in the 8.30 to 8.40 range, and that's in a 03 quad cab
2003 QC HEMI. 8.46@ 79.50, fastest NA 03 QC
Sidewinder cam, power wire,Tmr delete, edge 2800, hedman long tubes , Hedman ory pipe, 3" cutout, magnaflow 24", k&n CAI,Sharadon stage 3 VB, 4.56's, superchips 91
Old 08-22-2012, 06:42 PM
Rep:49
Heck yea Thanks for the heads up and saving me some money from an unhappy buy, I owe you a beer one day if we ever meet, but for now Ill give you some star power
hemi torque converter
