Old 07-17-2012, 03:44 PM
brokedodge brokedodge is offline
Vehicle: 98 ram
brokedodge is on a distinguished road
Default No Start
98 5.2 has no start
Took off alt cable to get to CTS plug, cable touched ground
Now no start
repl crank sensor, coil pck up, ECM was replaced and flashed, tried the ign on/off X2 and cel does not blink
HELP PLEASE dunno what to check and or replace
Old 07-17-2012, 03:53 PM
RcsbHemi's Avatar
RcsbHemi RcsbHemi is offline
Vehicle: 2010 Ram Rcsb
Trim Level: SLT 4x4 3.92
Color: PDM Metallic Gray
Rep:32
RcsbHemi is on a distinguished road
Check for a burnt fusible link, also check all fuses.
Mods: Magnaflow DOD14(resonator removed) line-x, tint, silverstars, tonno pro trifold tonneau, LED Licence plate and reverse bulbs, 2- 27w led fog lights behind grille. more to come........
Old 07-17-2012, 06:43 PM
Vehicle: 98 ram
No fusible link visible, can you give me some clue to where it is located?
Thanks
Old 07-18-2012, 01:57 AM
RcsbHemi's Avatar
Rep:32
The fusible like is in line with the cable that you grounded. That likely caused it to burn out, follow the cable from the alternator to the other end and there should be a bulge in the wire(that is the link). Disconnect it from the alternator and at the other end and check for continuity. If it is burnt you may need to replace the cable. Good luck.
