Place your Ad Here!
Old 07-17-2012, 03:08 PM
BobzRam BobzRam is offline
Rep:74
BobzRam will become famous soon enough
Default Pinion nut/ Rear end failure Poll Info wanted
Hello all. After looking around I see that there are a number of reported rearend failures, some from pinion nuts that loosen and others that are from various reasons. My question to you all, is if you had a failure, what diff do you have? Was it a limited slip or open? What ratio? What year? Was it pinion nut related or other? I am trying to get a grasp on the most common failures to get a better idea if it is limited to a particular rear, or if it is across the board on all of them? I am concerned with the problem and want to watch out for it. Or is it even really that common? Your input would help.
Thanks.
Old 07-17-2012, 05:44 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
I've never heard of those problems before & I'd have to assume they apply to later models after Dodge changed something big. And why they would is beyond me -- my '98 came with a Dana 60 front, Dana 70 rear & you have to work really, really hard to tear those up !!
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-17-2012, 09:34 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
We are talking Ram 1500's with the 'Corporate' rear ends. Years most affected seem to be 08-10, dosnt matter what ratio, 4x4 or 2wd. The issue is big if it happens to you.
The Dana 44 was better than what they install nowadays.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 07-18-2012, 12:44 PM
Rep:74
No doubt that the Dana rear was beefier than the new ones. But thats not what I am looking for here. I want to see if this is indeed a big issue or a small problem.
Old 08-02-2012, 04:34 PM
Almond 04's Avatar
Almond 04 Almond 04 is offline
Trim Level: Big Horn SLT
Color: Austin Tan Pearl
Rep:30
Almond 04 is on a distinguished road
2010 Ram 1500 SLT 4X4 Crew Cab 40K miles
Pinion nut failure.
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DS8S Conventional Differential Rear Axle
Cabin A/F mod / Mopar CAI / 390hp hood spears / Extang Trifecta / Custom Badges / Interior-Exterior LED's / Painted eng cover
Old 08-02-2012, 05:13 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
My pinion nut backed off slightly causing a leak which I caught and took to the dealer. I cant say if it was manufacturer or dealer error since my gears were upgraded to the Mopar 3.92/LSD by the same dealer. All I know is it was leaking and now it is not.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 08-03-2012, 08:29 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
I did a little investigating and it seems my suspicions were on track. The pinion needs to be about a half inch longer, as well as the pinion yoke. The yoke could stand to be longer yet, but the pinion bore def needs to gain that half inch or so.
To put it in perspective the 9" ford has a 1" longer bore length in its pinion yoke.
Also of note the 9.25 has a similar bore length to the early 10.25" ford which shared the pinion nut problem until they lengthened the pinion, and yoke bore
Silence! Differing opinions will not tolerated
Old 08-03-2012, 08:34 AM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
Mine failed around 12K miles. 3.55 open diff. Never had a leak though.
Old 08-04-2012, 09:26 AM
Holleywud's Avatar
Holleywud Holleywud is offline
Holleywud is on a distinguished road
No problem here. I only have 17,000 on mine though. I religiously check underneath my truck for leaks. Be sure I'll be at the dealer first sign of a leak.
Old 08-07-2012, 01:33 PM
Shreve T's Avatar
Shreve T Shreve T is offline
Vehicle: 2013 black Gold
Trim Level: Larime Longhorn
Rep:27
Shreve T is on a distinguished road
2010 Crew cab.. 42,313 miles 392 LS no problems/issues
