Old 08-07-2012, 09:25 PM
cj1's Avatar
cj1 cj1 is offline
Vehicle: 2010 Dodge Ram1500, 2004 600RR
Trim Level: SLT Sport
cj1 is on a distinguished road
2010 1500 sport 3.55 gears, open diff, pinion nut backed off around 18,000km and i had a slight whine, Dodge tightened it, but clearly not properly, and then at about 27,000km the whine started again, and got really bad, really fast, it was crazy loud! Anyway another dealer replaced only the bearings, road tested it then realised the gears were flat spotted, so they re-rebuilt it with all new components again, i was without the truck for a week and a half. Its really sad to know im not the only person with this problem!
Old 08-07-2012, 09:38 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Hmmm . . . it does appear to be a design error -- wonder what the odds are of forcing a recall for all the models with that rear end?
I'd think it would be quite an undertaking, just from the fact that all the diesel models 1998.5 thru 2001 came with an injector pump that WILL fail @ some point in time & there never was a recall on those. I've had 3 of 'em fail, Bosch finally came out with an upgrade for Freightliner "Sprinter" vans (sold by Dodge & Mercedes too) that use the same pump & I recently got the best version that $$$ can buy ($2150) so I should never have the problem again, but although the dealer replaced the 1st one under warranty, I had to buy the next 2 :-(
Maybe someone can use a State "Lemon Law" to attack the pinion issue.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 08-07-2012, 11:37 PM
cj1's Avatar
cj1 cj1 is offline
yea, i guess this pinion nut issue is linked to the drive shafts falling off to? so we have drive shafts that fall off and rear ends that go, kinda makes me wonder wtf is going on with dodge... there should be a recall, but chances are they looked into the problem and its going to cost them to much to recall and replace diff's or w/e to fix this issue.
Old 08-10-2012, 03:39 PM
OzPlanet's Avatar
OzPlanet OzPlanet is offline
OzPlanet is on a distinguished road
Pinion nut backed off 54,000km 3.92 lsd had gears and bearings all replaced. Happened really quick while on the highway heard the whine pulled over immediately. Took a week to get parts and repairs.
Just call me OZ....!
Old 08-10-2012, 05:12 PM
Almond 04's Avatar
Almond 04 Almond 04 is offline
Vehicle: 2010 Ram 1500
Trim Level: Big Horn SLT
Color: Austin Tan Pearl
Rep:30
Almond 04 is on a distinguished road
A week dam your lucky. I been without my truck for 7 weeks yesterday. FML!
Cabin A/F mod / Mopar CAI / 390hp hood spears / Extang Trifecta / Custom Badges / Interior-Exterior LED's / Painted eng cover
Old 08-10-2012, 05:27 PM
OzPlanet's Avatar
I heard the parts are back ordered, sorry to hear you have a such a long wait. You would think they would look toward the aftermarket to get gears for those that have been waiting. I guess I was lucky that there were gear available. I also broke down in a small town so maybe they had some just sitting there being that is was not that busy.
Old 08-14-2012, 02:22 PM
grayghostky grayghostky is offline
Vehicle: 2009 Dodge Ram 1500
Color: Blue
grayghostky is on a distinguished road
Default Rear Pinion Nut Loose/Leak
2009 Ram 1500 60,000miles Rear pinion leak. Why can't we get a recall. Fixed myself no more problems...yet
Old 09-03-2012, 01:26 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Keep us updated and please let us know how you make out.......
Old 09-03-2012, 09:32 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
same problem here..same rear end...
Old 09-04-2012, 12:57 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
2010 Big Horn CC here - 3.55 gears - my pinion seal was leaking at 66k miles, but no pinion nut failure. It was probably leaking slightly before this but I failed to notice it as it was more or less seeping - not leaking enough to cause spots on my driveway.
I guess my question is - let's say you had a failure where the nut backed off, and they replaced everything - wouldn't it just happen again if it's a design issue? Or was it more of a manufacturing process issue where these weren't tightened down properly?
Or would Chrysler replace with different components?
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
