Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Body & Interior
Body & Interior 1st Gen Dodge Ram Body & Interior Problems and Questions.
Old 07-18-2012, 07:20 PM
lt1tyrell lt1tyrell is offline
Vehicle: 1983 power ram 150
lt1tyrell is on a distinguished road
Default 2wd drive and 4wd body swap
Hello, I just picked up a great running and driving 83 reg cab long box 1/2 ton with a terrible body and home made flat deck but I also know where I can buy a really nice 2wd cheap. Besides cutting out the hump for the t-case and swapping them, is there anything else I need to know? Have many guys done this? Can I remove the cab with the whole front clip (fenders, inners etc) still attatched? Thanks!
Old 07-18-2012, 09:18 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Yes you can but it's probably more work than just walking off the nose. Remove the fender bolts along the doors and the two bolts up by the radiator support and walk it off.
The amount of time it takes to walk the nose off is far less than the hassle of trying to fit everything over the engine etc...
Done it a couple times. Makes taking the intermediate shaft for the steering loose at the box easier as well as a few other things.
Old 07-19-2012, 01:14 AM
Ok thanks for the info, any thing else I should look out for?
Old 07-19-2012, 01:16 AM
I forgot one more thing, the 2wd has the turbine wheels which I like, do they fit on the 4x4's?
Old 08-23-2012, 02:03 AM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
If they are both 1/2 tons they should.
Old 08-23-2012, 03:26 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Not necessarily. Up til the mid-80's the trucks had different bolt patterns. The standard duty 2WD 5 lug patterns were 5 x 4.5" and the 4WD were 5 X 5.5". By the mid 80's this was standardized to 5 x 5.5" on 2WD and 4WD, but your '83 should have the smaller pattern, so they won't fit. If you 2WD '83 is 5 X 4.5", you're outta luck.
Old 09-16-2012, 01:42 AM
Trim Level: base
Color: blue/silver
Default Wheels
Sorry I had a senior moment. I just Picked up a 1973 D100 I think they are the smaller ones. Brining it home tomorrow.
I'll make it a point to take pictures of my stable and up load them.
Jerry
