Need Help Fixing To Purchuse Tires & Wheels - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 07-18-2012, 07:50 PM
briann1282's Avatar
briann1282 briann1282 is offline
Vehicle: 2016 Ram 2500 Crew Cab
Trim Level: Tradesman
Rep:12
briann1282 is on a distinguished road
Default Need Help Fixing To Purchuse Tires & Wheels
Sup Guys! I have a 2011 Ram 2500 MegaCab 4x4 stock suspension & wantin to purchuse some moto metal wheels an toyo a/t tires Friday, just want to make sure they fit 1st, i've been doing a lot of research, internet sayin yes an tire shop sayin don't think so, so i'd like your guys opinion, maybe someone has the same set up.
Toyo Open Country A/T 305/55r20
Overall Width: 12.40"
Section Width: 305
Load Range: E (10-Ply Rated)
Aspect Ratio: 55
Rim Diameter: 20
Measuring Rim Width: 9.5"
Load Index: 121
Max Load: 3195 lbs @ 0 psi
Speed Index: S
Sidewall: Blackwall
Overall Diameter: 33.2"
Rim Width Range: 9.00" - 10.00"
Tread Depth: 16.00/32"
Moto Metal 955 Chrome 20"x10"
Bolt Pattern: 8x165.1
Rim Width: 10
Rim Brand: Moto Metal
Rim Diameter: 20
Offset: -12
Rim Structure: One Piece
Number of Bolts: 8
2016 Ram 2500 Crew Cab Tradesman 6.4 Hemi
Old 07-18-2012, 09:34 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
I think they're too wide and will rub when you turn. At minimum, you'll have to cut some plastic on the back side and they'll probably hit the bumper. .... I could be wrong though
Old 07-27-2012, 07:36 PM
Sledlvr's Avatar
Sledlvr Sledlvr is offline
Vehicle: 2012 Powerwagon
Color: Black/Red
Rep:29
Sledlvr is on a distinguished road
thats only a 33X9.5 tire , yes, they'll fit no problem
37x12.50 17' Super Swampers , HID's, Bullydog tuner,Catch can,Volant Powercore CAI, 4" Dynomax exhaust for a 6.7 Cummins, Kenwood TM271 65w VHF radio,240mm Lightforce Blitz HID driving lights,Custom 8'x9' aluminum sled deck
Old 07-28-2012, 03:14 PM
Bikenut's Avatar
Rep:73
Well, did they work?
Old 07-28-2012, 10:39 PM
boomer boomer is offline
Vehicle: 2007 Ram 1500 quadcab 4x4
Trim Level: bighorn
Rep:20
boomer is on a distinguished road
A leveling kit is a good inexpensive way to clear 33s, better then triming or rubbing, they run about 200$ (+-)
Old 07-29-2012, 12:26 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
Not sure on the height difference between a 2500 and my 1500 but I cleared everything but the sway bar on my 09 1500 2wd with 305/55r20 Zeon LTZ's. may want to look at a rim with a offset closer to 0 a -12 may cause rubbing since it sticks the tire out. Leveling kit does help it look better and with a -12 offset rim you may need it.
Old 07-31-2012, 03:05 AM
Nick and Kels 08 Nick and Kels 08 is offline
Vehicle: 2006 Dodge Ram Megacab
Color: silver
Nick and Kels 08 is on a distinguished road
I have a 06 Megacab 1500 4x4 which is on a 2500 platform. I had to put a 2.5" HBS level kit to clear 305 55 R20 on 20 x10 XD ROCKSTARS. Im not sure with your truck being newer if there is any height difference. Now i dont have any tire rubbing issues at all. Just thought id add my comments to give yo an idea.
Old 07-31-2012, 03:08 AM
Color: silver
I forgot to mention my wheel offset is -24mm if this helps any
Old 08-02-2012, 06:53 PM
Fordconvert Fordconvert is offline
Vehicle: 2012 Dodge Ram
Fordconvert is on a distinguished road
Thumbs down
Leveling kits are cheap, get one to be safe and your truck will look better. If you ever plan to lift you should think about a different wheel though.
