Old 07-19-2012, 01:59 PM
studda studda is offline
Vehicle: 2001 Dodge Ram Sport
studda is on a distinguished road
Default Please Help!!! Stalling Problems
I have a 2001 Ram Sport with a 5.9 that stalls between 1900 and 3000 rpm. It is fine if I can get it above 3000. The trouble is getting it there. Also, when I remove the gas cap, there is a release of pressure. I don't know if this is related or not. So far, I have changed the spark plugs, plug wires, distributor cap, rotor, TPS, and coil. There are error codes saying that I have misfires. It wouldn't be so bad if it were a slight miss but the motor WILL NOT run between 1900 and 3000 rpm. It completely dies. I have to let off the gas or put it to the floor to get out of that rpm range. PLEASE HELP!
Old 07-19-2012, 03:08 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Are you throwing any codes after it stalls?
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 07-20-2012, 02:44 PM
The misfire codes are the only ones that come up. They only come up sometimes though. Also, it seems to run better when it is raining.
Old 07-20-2012, 02:51 PM
It does have a bad neutral starting switch, although, I don't think that would have anything to do with the missing.
Old 07-22-2012, 07:22 PM
Nobody has any clue what it could be?
Old 07-23-2012, 12:21 AM
Dirtydodge99
Fuel pump, bad injector clogged filter check the pressure going to the rail. Also do a compression test how many miles are on it?
Old 07-24-2012, 05:18 PM
It has 76k miles on it. I did a pressure test on the fuel rail and it was ~50# so I wouldn't think it would be the fuel pump or the filter sock. The motor seems to surge when idling also if that helps any.
Old 07-24-2012, 06:32 PM
sofast785 sofast785 is offline
Vehicle: 1999 Dodge Ram
Trim Level: slt sport
Color: red
sofast785 is on a distinguished road
sorta sounds like the IAC(idle air control) sensor is going bad or having trouble regulating air fuel mixture. Check for a vacuum line leak or a common problem on the 5.9 is the plenum gasket sucking air. Not all sensor codes can be picked up with a obd scan tool.
Old 07-24-2012, 07:16 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'm leaning towards an electronic issue. Do the gauges do anything funny between the mentioned RPM's?
I'm thinking dist or coil.
Old 07-25-2012, 01:43 PM
I have already looked into cleaning the IAC sensor and that is next on the list of things to do. What is the easiest check for a plenum gasket leak?
The gauges are normal. I already replaced the coil, distributor cap, and rotor.
