Old 07-30-2012, 01:58 AM
I really wish I knew what my offset is on my current rims, I love the wide stance I have and when I upgrade rims I want the same stance.
Check the back of the rim?
It is usuall found there....
Old 07-30-2012, 02:34 AM
Vehicle: N/A
Rep:1045
good idea. ill check in on that. I bought em used when I first got the truck, 100 bucks for all four.
Old 07-30-2012, 08:42 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
Yup, RansRam did and he will post it.
Ill provide the link to it once he does
Two black sports staring down all the phords at Tim Hortons
http://www.ramforumz.com/showthread.php?t=118099
Old 07-30-2012, 09:09 AM
Unless it was never printed on the back, it should be there. Size, width and offset.
Old 07-30-2012, 09:21 AM
TimW's Avatar
TimW TimW is offline
Vehicle: 2012 Dodge Ram
Trim Level: sport
Rep:161
I've decided I'm going with the ATX artillery's, much lighter Than the ATX slabs, so the Artillery's have a -12 offset, thats a change of 31mm over stock, so if my math is right, the inside edge of the wheel will move out approximately 1.22047 inches, which should compensate for the growth in width, which is aprox 1 inch
Old 07-30-2012, 11:34 AM
-12 is a very common offset for aftermarket wheels for trucks
This is the info I pulled from the site I use and found to be pretty accurate.
Info used based on OE setup and what you'll be using your wheel setup (35x12.5x70, -12 offset)
Let me know if this helps.
Suspension >>> 100% clear (leaves even more room than OEM)
Fenders >>> Package will stick out 56 mm (2.2'') farther.
Wheel wells >>> Will fill out the wheel well by extra 25 mm.
Old 07-30-2012, 05:27 PM
Vehicle: N/A
Rep:1045
fast, after looking, I didn't find anything other than ultra, and 16x10 so I googled it, looked at ultras website. there Ultra 164 Polished, and further research at Jegs revealed info of -32mm offset and a backspace of 4.25.
http://www.jegs.com/i/Ultra+Wheel/60...6185P/10002/-1
that's why there so wide lol.
Tim, those are a good choice, they'll look better on your truck than the Slabs I think.
Old 07-30-2012, 10:02 PM
TimW's Avatar
Trim Level: sport
Rep:161
Yeah, yeah, yeah, I know what you are up to, you just want to keep those slabs for your self, play the old reverse psychology, make like you don't really like them, then BAM, when we least expect it, up pops a picture of your Ram with the slabs on it
Old 07-30-2012, 10:23 PM
Yea....what ^^^^Tim^^^^ said
Old 07-30-2012, 10:30 PM
Vehicle: N/A
Rep:1045
solid theory as they have the offset I'm looking for.
