Old 07-20-2012, 01:11 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
naw, if I wanted to show that I would have done this,
I know...and was kidding....hence the 'wink'
But it is here now....still looks good
sales@revelperformance.com
Old 07-22-2012, 11:56 PM
TimW's Avatar
TimW TimW is offline
Vehicle: 2012 Dodge Ram
Trim Level: sport
Rep:161
Yeah I know you were kidding, I have to remember people at the other end of these things cany see facial expression or emotion, thus thew need for things like "lol", anyway just got back from the cottage, anybody from Ontario will know what I'm talking about when I refer to being in the 401 parking lot for 5 hours, you would think I would learn my lesson by now, but being up at the cottage is like being in heaven, its just never long enough
Old 07-23-2012, 01:05 AM
Vehicle: N/A
Rep:1045
good looking mods man. I like the third set of rims as well.
ALTHOUGH the second set might be something ill consider for mine.....
Old 07-23-2012, 01:18 AM
Vehicle: N/A
Rep:1045
where are you looking at the second set? I can't find em
Old 07-23-2012, 03:28 AM
Revel Performance
Rep:1804
This is summer driving for our now. Our highways are crap.... Too congested
Old 07-23-2012, 07:45 AM
TimW's Avatar
Trim Level: sport
Rep:161
I hear you man, Whitby to Oshawa is the worst, its just a huge choke point, anyway, back to work
Old 07-23-2012, 12:49 PM
Revel Performance
Rep:1804
You past right by me..... Im in Scarborough/Pickering border
We should have connected....but Im sure you wanted to get home and not get stuck in traffic
Next time
Old 07-24-2012, 08:13 PM
TimW's Avatar
Trim Level: sport
Rep:161
Does anybody out there know what the factory offset is on these 20 inch chrome clads, 3 dealerships and a whole lot of blank stares, shirley this info must be out there somewhere, I just cant find it, and I need it to figure out which wheel Im going to buy, one I'm looking at is negative 10, the other is negative 38, any help would be appreciated
Old 07-25-2012, 12:44 AM
Revel Performance
Rep:1804
Tim, it's 20x9, +18 offset (others say +19)
It's one or the other but it's accurate
What tire size are you planning on running?
Size of rim and width?
Old 07-25-2012, 08:58 AM
TimW's Avatar
Trim Level: sport
Rep:161
As it stands right now, the stock tires are about 10 t0 10.5 inches, I want to run something in the order of a 35, BFG All Terrains go to 315 X 12.5 wide, everything else like MT, Cepek, Pro Comp are 35 X 12.5, any way, there is approximately 1/2 inch clearance between the upper A arm and the tire now, and ythats with the 10 inch wide tire, if I want to fit a 35x12.50x17 I am going to have to move the inside of the tire out at least an inch, I'm not a fan of spacers, so that means I need to find a wheel with sufficient negative back spacing, those ATX Artillery's are -10 ofset, so that means there would be a change in offset of 28 to 29 mm, 25 mm is approximately 1 inch, the ATX slabs were -38 offset, so that would mean a change of 57mm which is approximately 2 inches, assuming of course I'm doing the math correctly
-10 mm offset
-38mm offset
