Old 07-25-2012, 08:32 AM
As it stands right now, the stock tires are about 10 t0 10.5 inches, I want to run something in the order of a 35, BFG All Terrains go to 315 X 12.5 wide, everything else like MT, Cepek, Pro Comp are 35 X 12.5, any way, there is approximately 1/2 inch clearance between the upper A arm and the tire now, and ythats with the 10 inch wide tire, if I want to fit a 35x12.50x17 I am going to have to move the inside of the tire out at least an inch, I'm not a fan of spacers, so that means I need to find a wheel with sufficient negative back spacing, those ATX Artillery's are -10 ofset, so that means there would be a change in offset of 28 to 29 mm, 25 mm is approximately 1 inch, the ATX slabs were -38 offset, so that would mean a change of 57mm which is approximately 2 inches, assuming of course I'm doing the math correctly
-10 mm offset
-38mm offset
Your math is fairly close and accurate
But you still need to factor in the tire to get true width
Stock tires are 10.8" wide. The clearance between tire and control A arm is between 5/8"-3/4"
Regarding aftermarket....
Tires are tires. Tires cannot be moved out....but it can be moved out with a negative offset rim or something less than stock.
Toyo MT's do have a 35x12.5x17 available. (34.8x13.2)
I'll assume that those 17" wheels are 9" wide and use that in the example and using the toyo MT tire above
-10 offset:
You'll be 2mm (0.1") closer to the control arm and you will stick out of the fenders by 58mm (2.3")
-38 offset:
You'll clear the control arm and have much more space than stock wheels but you will stick out of the fenders by 86mm (3.4")
Either way, you have the pocketflares so you'll need to find out how far you want the wheels to stick out to either be flush with the fenders, tucked in or further out.
Either wheels should be ok.
I believe you're leveled....can't recall.
Hope this helps.
Old 07-25-2012, 08:40 AM
TimW's Avatar
TimW TimW is offline
Vehicle: 2012 Dodge Ram
Trim Level: sport
Rep:161
Hey Fast, don't know if you saw it but I sent you a pm about the flares
Old 07-25-2012, 10:21 AM
Yup! Got it and responded.
Thought I would respond to your thread first
Old 07-25-2012, 03:14 PM
Vehicle: N/A
Rep:1045
those atx slabs would give you a nice wide stance man....
Old 07-25-2012, 03:45 PM
True....but IMO, they look like they are for diesel trucks/2500/3500 or tow trucks
Just my opinion....
Old 07-25-2012, 03:46 PM
Vehicle: N/A
Rep:1045
Just my opinion....
hehe that's why I wanted em!
.......until I saw the price tag!
Old 07-25-2012, 04:37 PM
LOL! Are they that bad?
Old 07-25-2012, 04:41 PM
Vehicle: N/A
Rep:1045
yea... 402 $ for a 17x9
I'm sure they can be found cheaper but that's steep for me.
Old 07-25-2012, 06:24 PM
TimW's Avatar
Trim Level: sport
Rep:161
Aw come on, They are on ebay for $1,568.50, thats only $392.13, and when I spoke to them they were going to throw in a set of new wheel nuts, gotta be worth 30 bucks, hell that brings the price down to $384.63, hell they are practically giving them away
Old 07-25-2012, 06:26 PM
Vehicle: N/A
Rep:1045
see he found em cheaper! lol
