hauling stuff in bed question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Ram R/T
Old 07-20-2012, 12:27 PM
chuckie chuckie is offline
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
chuckie will become famous soon enoughchuckie will become famous soon enough
Default hauling stuff in bed question
I have an '11 R/T with 2/3 lowering kit. I have to pick up 600 lbs of floor
tile I ordered. Do you think it would be ok to put all this in the bed ?
Worried about bottoming out on the drive home. Or should I just go rent a uhaul trailer and tow it?
Old 07-20-2012, 12:53 PM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
It is a hlaf ton truck, it is capable of carrying 1000lbs +/- in the bed. As long as the drop kit didnt change the spring rate you should be fine. If you have gone to a softer rate then you might want to consider a trailer.
Just Got it, Give me time!
Old 07-20-2012, 12:58 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I believe the RT payload is like 1,200lb. You should be fine. Even if it's a softer spring rate I doubt they'd make it so soft it reduces capacity by 50%. And if you bottom out it isn't even a big deal, there's bumpers that take the impact. You should be fine though. And if you load it as close to the cab as possible more weight will be up front...
Sean
Old 07-20-2012, 07:53 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
Sit a couple guys in the back and drive over down the street. Easiest way I can think of checking but it should be fine if it was a mini truck and lowered then I might say check it but 600 lbs isn't that much weight just push it toward the front of the bed and that will distribute the weight a little better
Old 07-20-2012, 08:37 PM
Firehawk's Avatar
Firehawk Firehawk is offline
Vehicle: 2011 Dodge Ram
Trim Level: Express RCSB/2WD
Color: Mineral Gray Metallic
Firehawk is on a distinguished road
Send a message via Yahoo to Firehawk
You should be fine. Even if it's a softer spring rate I doubt they'd make it so soft it reduces capacity by 50%.... You should be fine though. And if you load it as close to the cab as possible more weight will be up front...
↑↑↑↑↑↑ My truck modifications list is located in my forum profile. → → →
Old 07-20-2012, 11:57 PM
Rep:2954
make 2 trips if you are really worried
unless you have a friend with a trailer
don't go out & rent one
Old 07-21-2012, 12:08 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
I gotta say I have had some 1500 plus loads in my truck already and its no challenge for it. I would think your good to go.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 07-28-2012, 11:40 AM
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
Thanks for all the advice. I loaded the tile forward as possible and made the trip home fine. No bottoming out. Will spend this weekend laying the tile.
Old 07-29-2012, 04:38 PM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
this is a 2/4 McGaughy with about 1000# in the bed. No bottoming out, or any other issues on the 30 mile trip.
07 rclb cummins. Efi live by silver bullet tuning
