Old 12-14-2012, 07:18 AM
Jocce Jocce is offline
Rep:82
Jocce will become famous soon enough
Default Replacing the driver-side mirror?
How do I replace and / or take apart the driver-side rear-view mirror?
A couple of weeks ago I accidently cracked it against a pillar in a car park
It's working fine, but one of the turn-signal leds (?) and some of the "follow me home" leds have stoped working.
Where can I order a new one, or perhaps just parts of it (Propably need the outer plastic shell and perhaps the leds, everything else is ok!)
/Jocce
Old 12-14-2012, 01:23 PM
BigTJohn's Avatar
BigTJohn BigTJohn is offline
Vehicle: 2012 Ram 2500
BigTJohn is on a distinguished road
Default Mirror Replacement
Here are the steps to do so:
1. Remove the bolt cover on the door.
2. Remove the plastic screws from the door panelp3.jpgUse a screw driver but use your finger nail under the screw to help it come out. Then remove the plastic insert from the panel - 8, two on the bottom and 3 on each side.
2a. Lift the little "door" at the open door release handle, remove the large phillips screw.p2.jpg
2b. Lift the inset panel (with the little door you opened) from the forward portion of the handle area and gently pry up and forward while "opening" the door release handle and remove it.
3. Lift the panel from the door enough to clear the lock buttonp5.jpg - BE CAREFUL AS THE WIRES ARE ALL THAT HOLDS THE DOOR PANEL TO THE DOOR AT THIS POINT!p6.jpg
4. Support the panel - either with the door lock button or some method to ease the stress on the wires, then unplug the mirror wire plug.p7.jpg Just follow it down from the mirror.p8.jpg Also cut the tape holding the wire to the door.p9.jpg. When you put the new mirror back on, use zip ties to attach the wire to the plastic stress relief, it is easier then wrapping with tape.
5. Use a 10 mm socket, remove the nuts holding the mirror to the door -p10.jpg BE CAREFUL, HAVE THE WINDOW DOWN SO YOU SUPPORT THE MIRROR WHEN THE LAST NUT IS REMOVED.p11.jpg
6. Take the mirror out from the door and set it aside. There is a spring clip that may come out with the mirror, make sure you put it back into the slot on the door. p12.jpg Now all you have to do is reverse these steps and install the new mirror.p13.jpg
Pretty easy to do if you follow those steps. Just try the new mirror before you button it all up to be sure it works.
"Life is not too short, just that you are dead for so long..."
Old 12-17-2012, 03:37 AM
Rep:82
Thanxs! Will have a look at it some day
/Jocce
Old 12-17-2012, 03:41 AM
TVL's Avatar
TVL TVL is offline
Vehicle: 2012 Ram 1500 Crew
Color: Black/Silver
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
/Jocce
I also did an OOOPS! with my passenger side mirror about a month after I bought my truck. I had a new one installed for $550. ouch
Hello, my name is Tim and I'm a modaholic.
MODS: 6" RCX Lift, 37"X12.5R20 Trail Grapplers on 20" Moto Metal 962 Black/silver rims, remote tailgate lock, Bakflip G2 tonneau cover, LineX spray-on bed liner, Amp Research Power Step, magnaflow 18" muffler, S&B CAI, Passenger Front Ejection seat, Diablosport Trinity1000 tuned with Hemifever 89 tune, Spyder Projector/HID 8000K/CCFL Halos/LEDs Headlights, Retroshop Projector/HID/8000K/CCFL Halo Fog Lights, Recon LED Smoked Tail Lights & LED Smoked 3rd Brake Light, fully stocked bar w/tap, BT Catch Can, Chrome & Black Mesh studded Grille, HID Reverse Light Kit, customized tailgate badge....more to come!
Old 01-11-2013, 07:48 PM
Scotty85's Avatar
Scotty85 Scotty85 is offline
Vehicle: 2012 Dodge Ram
Color: True Blue Pearlcoat
Rep:79
Scotty85 will become famous soon enough
My God I love this forum! Now THAT'S an answer!!
Awesome...
Scott
2012 RAM Sport CC Hemi - Photos here:http://www.ramforumz.com/showthread.php?t=132968
Audio Mods - http://www.ramforumz.com/showthread.php?p=1005034
Perf. Mods - http://www.ramforumz.com/showthread.php?p=1005080
Body Mods - http://www.ramforumz.com/showthread.php?p=1005083
Old 01-12-2013, 01:54 AM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
I've got a '12 1500 which came with the tow mirrors (flip up kind, power, heated, turn signal, puddle light).
I'd like to swap for Black Plastic Non-Tow mirrors (in excelent condition) with the same features - power, heated, turn signal, puddle/courtesy light.
I'm in Lemoore, CA (near Fresno)
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
