Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-21-2012, 09:38 PM
daredevil95 daredevil95 is offline
Vehicle: 2001 Dodge Ram 1500
daredevil95 is on a distinguished road
Default A/C Problems
Hi, I have a 2001 Dodge Ram 1500 with a 5.2 engine. The A/C wasn't blowing cold so, I bought a can of freon and charged the system. The A/C blew nice and cold and worked for a few days. The A/C stopped working a few days later. I have a Freon leak somewhere in my system. Does anyone know what is a common leak area for this A/C system and does anyone know how many o-rings are in the A/C system. I'm guessing that I need to change the O-rings, anyone ever go through this before and if so, any info will be appreciated.
Old 07-22-2012, 01:18 AM
valleyoaks valleyoaks is offline
Vehicle: 1996 Dodge Ram Sport
Trim Level: sport
valleyoaks is on a distinguished road
look for leak on lines,at fittings,accumaltor could be rusted with a pinhole,evaporator list goes on,get a can of dye with the dye light and thats the easy way to determine
Old 07-22-2012, 11:27 AM
sounds good. thanks
Old 07-22-2012, 11:52 AM
Grubrunner's Avatar
Rep:3883
Is your compressor turning on?
Grub out!
Old 07-22-2012, 06:33 PM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
you can buy freon with dye in it, run it through, than check with a black light to see where the leaks are.
Old 07-22-2012, 06:45 PM
At first the compressor would turn on then turn off after a couple seconds, I filled the system with a large can of freon, the A/C worked great and compressor worked good. After a few days it appears as though the A/C freon is leaking out, the A/C compressor now goes on and off every few minutes and the A/C isn't as cold. I'm pretty certain the A/C system has a leak. I guess I'm gonna have to buy a can of dye and a black light and search for the leak.
Old 07-22-2012, 09:01 PM
Thanks, I'll give it a try.
Old 07-28-2012, 01:36 PM
zachcroft zachcroft is offline
Vehicle: 1996 dodge ram
Color: green
zachcroft is on a distinguished road
i had the same problem. being an hvac technician though, i had access to and electronic leak detector."sniffer" my leak was at the first o-ring coming from the condenser coil going towards the evaporator.
Old 07-28-2012, 07:16 PM
Grubrunner's Avatar
Rep:3883
Can you hear the pressure relief valve kicking in? It's an obnoxious "hiss" sound so you'll know it when you hear it.
Grub out!
Old 07-28-2012, 07:44 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Let us know how you make out,.....
