Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 07-22-2012, 02:31 AM
87DR 87DR is offline
Vehicle: 1987 Dodge Ram D150 LE
Trim Level: LE D150
Color: red
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
87DR is on a distinguished road
Default "87 Stance issue
howdy i am a new prowd owner of a all original 1987 Dodge Ram 150, red in color, 318 non magnum, 2brrl 140 hp (yuck! my honda accord has 20 m0re)
...anyways...ive noticed its stance was higher in the rear and low in the front, is this a normal stance for this model? and feels top heavy in turns, like a boat. i know this is a old truck (original second owner) well taken care of, only 82k+ miles on it...being said, i dont think the shocks are bad, or replaced at that. it rides great, to my surprise. is it all right to add a coil spring lift on the front to level it out or lower the rear and try to get a better firmer handling , wich i think a stronger stableizer bar will handle the sway...SO...please any feed back any imfo would greatly appreciated...thanx
Old 07-25-2012, 10:47 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
The rear end is typically higher to allow for a load which can set the back end down quite a bit. And you want to have a lot of spring travel so a load won't bottom the springs/shocks out. If there are blocks between the rear axle & the leaf springs you can remove those to lower the rear end & not lose any spring travel but if not you could get longer springs for the front. Just be aware that if you do carry heavy loads from time to time you'll have the opposite effect -- rear end being lower than the front.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
suspension leveling
