Old 07-22-2012, 12:37 PM
01ram121 01ram121 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Silver
Color: Blue
01ram121 is on a distinguished road
Default Clunking and Knocking in 4 wheel drive
ok so i got a problem and i am pretty lost on a solution. my 01 ram 1500 w/ 5 inch lift has a nasty knocking or clunking sound coming from directly underneath the driver and passenger seats. i had all front u-joints replaced and also the CV joint and still the clunking. it only happens in 4wd while i was at the beach on sand and gets louder on turns. the guy who is helping me has worked on trucks specifically for over 30 years and he is also a little lost. he has ruled out a transfer case issue or any gear issue which i still have a feeling it may be. tomorrow we are taking the cv joint out again and bringing the driveshaft to a driveshaft guy and he will grind it down a little to add room. they think there may be a bad angle with the driveshaft due to the lift. any other ideas out there..... thanks for any help
Old 07-24-2012, 01:05 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
There's only one way to fix that problem -- return the driveline angles to stock. Angled lift blocks solve the problem with leaf springs, but it's more difficult with coil springs & I'm not aware of any aftermarket products for that job. However, I would assume there are some -- such as pieces like those used in a "leveling kit" but angled to turn the axle up @ the correct angle for the driveshaft.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
