Old 07-22-2012, 09:37 PM
gnomore gnomore is offline
Vehicle: 2012 Dodge Ram 1500
gnomore is on a distinguished road
Default Front end way too low...
Is it me or is the front end of these trucks way too low... The bumper itself if already low, then dodge has a 6 inch piece of plastic hanging down. I cant even get the front of the truck over some of the parking curbs in the area.
Rather than lift the front of the truck up, is it possible to take the plastic thing under the front bumper off? Would this void the warranty in any way?
Old 07-22-2012, 09:57 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
And here I am thinking its way to high... Eventually would like to drop mine 2/4 or even better 3/5. ANd taking the plastic thing under the bumper should not void any warranty.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 07-22-2012, 09:59 PM
Dutch Dodge Dutch Dodge is offline
Dutch Dodge is on a distinguished road
It should not void the warranty, as stated before. That plastic part of the bumper is only there for the aerodynamics
Old 07-22-2012, 10:07 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
Removing the plastic piece isnt gonna void your warranty. But its there for a reason, it protects your bumper. If you remove that, you'll then think you have more ground clearance, making you drive over bigger curbs. The way it is now, you drive over smaller cubs and the plastic piece takes the beating. Without the plastic piece, the bumper will take the beating....
Do what you want, but I say leave it on and install some coil spacers in the front.
Either 2" or 2.5"
MATT
Old 07-22-2012, 10:18 PM
CaptJon CaptJon is offline
Vehicle: 2012 Ram 1500
Rep:41
CaptJon is on a distinguished road
Either 2" or 2.5"
Exactly what I was thinking but only after you said it so I guess I agree with you.
Old 07-30-2012, 10:46 AM
shadango shadango is offline
Vehicle: 2012 Dodge Ram 1500 Big Horn
Rep:25
shadango is on a distinguished road
Either 2" or 2.5"
But....if he removes the air dam, he DOES have more clearance......the 6" that the damn is using now.
If he drives over the small curbs etc and the plastic hits now but not the bumper, he wont have ANYTHING hit if he removes the plastic piece.
The plastic dam doesn't really "prevent" damage....it just takes the damage at that level. The bumper wont be damaged if he goes over something that would have hit the dam only.
I think what you were saying is that it lets you "hear" when you are running out of clearance......true. But it is reducing the clearance by that much.
I am considering doing the same thing.....just looks too low.
Plus, the snowplowing effect in the winter and on the beach. But , without the dam, may get more water/dirt/sand sprayed into the engine bay since there is no "bottom cover" like my Durango had.....
A front end kit will raise the front end, but result in a drooped rear end when towing.....plus, it will likely void the warranty if what I have read elsewhere here is true. Pulling that air damn off is an easy way to pickup a little extra clearance IMHO.
Old 07-30-2012, 11:37 AM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
That air dam thing got ripped off my truck in less than 500 miles. Tossed it in the recycle bin and put in new springs to level it up. I like the look better without it and I do not believe it gives more than maybe .1 mpg improvement installed.
Old 07-30-2012, 12:10 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Either 2" or 2.5"
Also agree here, lift it
Old 07-30-2012, 01:20 PM
Rep:25
Thats kind of my thinking too.
The side of the truck is plenty high as far as clearance. Rear end seems high enough.
Then they tack on that thing and cripple it on the front end...not to mention the lower bumper to begin with.
I wait years to finally buy a new pickup and they turn it into a small SUV as far as front ride height...LOL
Old 07-30-2012, 01:55 PM
Rep:1797
x3 on the level/lift
