Crank no start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-22-2012, 11:39 PM
Dirtydodge99
Default Crank no start
I posted something earlier today bit in the wrong section so I'm re posting here I just got a 99 ram 1500 4x4 it's in decent shape the interior is spotless I bought the truck not running it sat for a year the guy said it needs a fuel pump I got it home and the pump works but there is no spark and I think the guy knew that because there is new plugs and wires when you crank it over the rpm's move so I know the crank sensor is working and the distributed is spinning the coil looks old how common is it for them to go? I'm going to mess with it more on Wednesday Any ideas?
Old 07-23-2012, 08:23 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Coils can fail easaly. Usualy they go weak but can fail all together and a stock one is cheap enough. Did the plugs look like they have been fired?
Old 07-23-2012, 08:49 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Check the plug on the coil before you replace it
Old 07-29-2012, 12:44 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I've replaced the ignition coils on both of my dodge trucks, both went out with no warning at about 150k. cheap easy fix, thank goodness, both times I was far from home.
Old 07-30-2012, 10:47 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Check the starter and ASD relay.
