Two minor but annoying issues. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 07-23-2012, 06:43 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Trim Level: Laramie SLT
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
Default Two minor but annoying issues.
1st ... my passenger side door lock won't lock automatically for some reason, it instead just makes a continuous buzzing sound, like it's trying to lock but won't catch and pull the lock into the locked position. How do I fix this? Because I'm not quite sure.
2nd ... The passenger side rear door doesn't open from the inside, you can pull the handle but nothing happens, maybe something has disconnected or snapped. Not sure about this either.
Old 07-23-2012, 08:06 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
My truck did this yesterday (the passenger rear door), and somehow I guess someone hit the child lock switch but I don't know how! Check that out and see if it got switched
Old 07-23-2012, 05:50 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
1. could be a bad solenoid motor, pull the door panel
2. the rod might have popped out of the latch socket, pull the panel off
Old 07-23-2012, 06:23 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I second the door latch (solenoid). It has an internal actuator. You'll have to pull the door panel WITH THE WINDOW UP. Take out the 3 torx screws along the outside of the latch un-clip the outer handle mechanism (easier if you wrangle the outer handle loose after removing the 2 nuts that hold it from the inside), outer door lock, inner bar (they're color coded clips),, unplug the lock actuator plug and slide the whole thing down and turn it to get it past the window track.
Probably a good idea to check the child lock before proceeding.
