Need some help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-23-2012, 05:41 PM
99gp's Avatar
99gp 99gp is offline
Vehicle: 2004 Dodge Ram 1500
Rep:155
Default Need some help
I have a problem. I am having a squeak over bumps, so I took it in to figure out what is it. My lower ball joints are shot, and they gave me an estimate of $600 to do both lowers ..... I can get moog ball joints for 120ish, but I have never replaced them before. does anyone have any advice on how to do them? It is a 4x4 also. Thanks for any help
Old 07-24-2012, 06:02 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
You will need some special tools & if you can get your hands on a factory service manual it will make life MUCH easier as the procedure should be described in detail. A Chilton's etc. manual would be better than nothing, but see if you can get the factory manual -- they ain't cheap, but for a job like that it's worth every penny!
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-25-2012, 10:35 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
tools, manual? might want to leave this to a pro.
Old 07-30-2012, 02:09 PM
99gp's Avatar
Rep:155
Talking Got it done
Well guys, I got both my ball joints installed and they weren't as bad as I thought they would be to do. I got 2 moog lowers and my uppers and tie rod ends were fine. I rented the tools from advance auto and I love that its free to do. I also painted my calipers and control arms so they look good again.... One tip of advice is don't paint in a garage you will get over spray from it just being in the air and you will be spending hours rubbing it out
Old 07-30-2012, 04:51 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
Good job, props for doing it yourself!
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 07-30-2012, 05:40 PM
99gp's Avatar
Rep:155
Default How to change lower ball joints
Thanks. I was surprised at the fact that they weren't hard to replace.
Here are step by step process on how to replace lower ball joints on 03 4x4 ram
1) lift truck and support with jack stands
2) remove tire
3) Loosen axle nut while brakes are applied
4) remove brake caliper and caliper bracket
5) remove rotor
6) remove upper and lower ball joint nuts and tie rod end nut and pin
7) use a ball joint separator to separate lower and upper ball joints(pickle fork didn't work for me, had to have a separator, and this didn't rip the boots)
8) remove axle nut
9) remove tie rod end
10) disconnect the abs sensor wire clips
11) use a rubber mallet and tap the axle out of the hub
12) take off the hub housing bracket (not sure of actual name, but its what the hub bolts on, and where the ball joints attach). It wiggles out and is a tight fit
13) use a ball joint press and press the old joint out
14) use the ball joint press and press the new joint in. MAKE SURE ITS STRAIGHT, IT WILL BEND YOUR CONTROL ARM IF NOT STRAIGHT.
15) reassemble
Old 07-30-2012, 08:19 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Hell Ya! Reps. for doing it yourself and then posting the How to! Good Job Mang!
Old 07-30-2012, 08:24 PM
99gp's Avatar
Rep:155
Thanks man. I always love learning new things and helping our fellow people if I can
Old 07-31-2012, 11:15 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
That's awesome. I am going to have to replace my lowers eventually. I haven't priced it yet but I was thinking $600 sounds extremely expensive. Best I can tell (and according to what you posted) it really isn't that big of a job. Congrats on a job well done.
I'm going to refrain from cracking on you for your comment about "spending hours rubbing it out"....lmao.
Old 07-31-2012, 04:53 PM
99gp's Avatar
Rep:155
If you attempt to do the ball joints yourself save yourself ALOT of headaches and rent the correct tools. You have to rent the ball joint press but I highly recommend renting that ball joint seperator that I posted also. It not only makes the job faster, and easier but it saves the boots on the upper ball joint if your only doing lowers.
Also my hours rubbbing it out its fine to make cracks on me. It was a stupid mistake I made and I am expecting to get ripped on a little bit. Thats why I posted it, so everyone can get a laugh at my expense .
