Help. 92 D250 5.9 gas burner starts but sometimes wont rev up - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 07-23-2012, 08:36 PM
Lawnmowerman's Avatar
Lawnmowerman Lawnmowerman is offline
Vehicle: 1992 Dodge Ram D250
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
Lawnmowerman is on a distinguished road
Default Help. 92 D250 5.9 gas burner starts but sometimes wont rev up
like the title says sometimes it starts and quits and smoetimes it starts and idles fine but wont rev up. it just fades away. I have bought a book and checked the TPS but it works fine. it came out with a few different codes but i dont know how to reset the ECM..
Old 07-23-2012, 10:29 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Disconnect the battery, go do something else for a few minutes, come back and flip the headlights on and off a couple times. Re-connect the battery. Your computer is reset. Clearing the codes won't fix the problem. What are the codes? Probably several little things that are conspiring to cause the problem.
Old 07-24-2012, 07:23 AM
I know it wont fix anything but it will cause the computer to reset and when it does it again it should be the first couple of codes to show up.. right now it has several different ones.. i think i will be investing in a code reader... also because some will not show up thru the check engine light... But thanks for the help
