Old 07-24-2012, 01:01 AM
el6nino9 el6nino9 is offline
Vehicle: 96 dodge ram
Trim Level: ext cab 1/2 ton 2wd
Color: green
el6nino9 is on a distinguished road
Default 96 ram 318 loses power to coil and injectors sometimes....
318 engine. Sometimes this truck will lose power to the coil and injectors, has great fuel pressure always, sometimes will be driving and it will just cut out and die and you have to wait a few minutes and it will fire back up, all the time when you rev it it will be a lil hesitant right at first but revs fine with no miss, but when it comes back down to idle it will stumble a lil sometimes clearing out sometimes dying, its had 2 codes pull 1) engine coolant temp sensor which I found broke I replaced and it does ever show temp in gauge but all other gauges work, 2) coil misfire yet I've replaced the coil as well and no change, also replaced the crank sensor and no change also checked the asd relay and was fine also I noticed it does not change in idle when ac lights and turning the wheel all are on
Old 07-24-2012, 11:27 AM
Color: green
I think I may know why its acting up, the motor I put in a year ago came from a durango that I believe doesn't have a coolant sending unit, as there is an extra harness plug near the sensor that I know went to an extra intake plug that this durango intake does not have, unfortunately that other intake is long gone....
Old 07-24-2012, 11:35 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Also check auto shut down relay. If the broken sensor you had was behind alt in intake that one is air temp sensor.
