01 5.2 issues - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-25-2012, 10:08 AM
dommie699 dommie699 is offline
Vehicle: 2001 dodge ram 4x4
Color: brown
dommie699 is on a distinguished road
Default 01 5.2 issues
hello, i am new to the forum and would greatly appreciate any help. i have an 01 ram 4x4 with 5.2. when started cold it starts right up and idles then starts to overload with gas and almost stall ,it will run for about 3-5 min and then start running great. it will usually run fine all day unless it cools down and it does this everytime. i purchased the truck from a friend and this is what he had done to it and replaced on it: new tps sensor, idle sensor, map sensor, o2 sensors, new catylic converter, new fuel pump , muffler and full tune up. does not pull code most of the time but did pull evap code before. any help would be awsome
Old 07-25-2012, 10:36 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Check all hoses to purge silonoid its on right fender behind horns. Look for cracks mainly in big hose where bend is formed. Also make sure iac motor is working. Its at back of throtle body plunger should move freely. Also check air temp sensor. Its behind alt in intake manifold. These can cause over load and poor perfomance when cold.
evap, stall, stalling
