Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 07-25-2012, 04:18 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
Default Trouble changing shocks...
Any one have any tips on how to get the bolts out of the bottom front shock mounts? I have tried hammers, to no avail. Is there something I'm missing here?
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 07-26-2012, 07:06 AM
valleyoaks valleyoaks is offline
Vehicle: 1996 Dodge Ram Sport
Trim Level: sport
valleyoaks is on a distinguished road
just did mine yesterday,keep unscrewing the bolt is long and held by a retainer on other side,still got a noise in front end as all my parts are new except control arms and the bushings are in good shape
Old 07-26-2012, 11:20 AM
Color: tan
Rep:65
Ok that makes sense...so keep unscrewing the bolt after the nut on the other side is off?
Old 07-27-2012, 07:45 PM
Color: tan
Rep:65
Ok, guys...I have changed the passenger side shock...Bolt just unscrewed all the way out.
Driver's side the bolt will unscrew the retainer nut but the bolt will NOT unscrew out of the shock mount at all...I have tried using a hammer, air hammer, and I turned the bolt for about 15 minutes...nothing...
Is there a nut welded on the inside of the A-arm? Maybe that has come loose and that is why the bolt won't come out?
Old 07-27-2012, 08:05 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Sounds like a combination lock.
You're probably going to have to use a combination of putting pressure on it and spinning it at the same time. Sometimes the bolts get worn down by the rubber and it creates a groove. Try applying pressure in the outward direction and spinning it at the same time.
Old 07-28-2012, 06:19 AM
Trim Level: sport
a jack or someone to help put pressure on the side of the truck as to wiggle the bolt out,,if you beat on it you may end up having to get a new bolt as you will damage the threads
Old 07-28-2012, 12:12 PM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2015 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
i had the same problem passenger side was easy driver side i used a good size hammer and a pinbar luckily i didnt damage threads but bolts r cheap. goog luck
Old 07-28-2012, 12:42 PM
Vehicle: 95
Rep:1776
Are you swinging the hammer like a little girl? JK
I have an old pry-bar (they actually make 'em now) that I ground a "V" in the end. I get it under the head of the bolt to apply pressure and tap the other side.
It usually winds up with the pry bar coming perilously close to my teeth on at least one pass or narrowly missing my head. I thought it may be important to mention that to you.
Old 08-01-2012, 01:08 PM
Color: tan
Rep:65
Naw, Warlock, I'm wacking the thing like hell...I tried the prybar....came at me flying a couple of times but I was expecting that...
Funny thing is, if you tighten the bolt (not using the retainer nut) the thing will actually TIGHTEN UP....I'm planning to try this again with a buddy this weekend so it will either come loose, or we will break something important...LOL!!
Old 08-01-2012, 01:15 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Your gonna have to have pressure as your unscrewing it...
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
