Old 07-25-2012, 09:19 PM
Crobber's Avatar
Crobber Crobber is offline
Vehicle: 2001 Dodge Ram Sport 4x4
Trim Level: Sport 4x4 SLT
Rep:26
Crobber is on a distinguished road
Default Roll Bar will fit 2nd Gen?
Will a Roll Bar off a 2002 Dodge Fit a 2001? both 1500. I know that is the year they switched looks/gen. but did they alter the bed sizes. I do know know anyone nearby with a 3rd gen to get measurments.
I did some google research and did not come up with any definitive answers
"You can't just give up hope and walk away, Cause when you do that then there is no hope at all."
Old 07-29-2012, 11:33 PM
Crobber's Avatar
Rep:26
Well decided to take a chance and go ahead and buy the roll bar. I had my friend measure his 3rd gen truck bed and the measurements came up very close.
So to answer does a Roll bar from a 3rd gen fit a 2nd Gen?
Almost. Its needs about 2 inches to the wheel wells to fit perfectly as you will see in the photos.
These are the parts I picked up.
First stages. It was rather difficult putting the roll bar together in the bed of the truck.
Attatching the bar to the outside hole. My first mistake
I compared the where to put the support bars on the inside or outside hole. Later found out it has to go on the inside hole. As the outside caused the bar to rub on the walls of the truck
It had to sit about an 2'' back due to the supoort beam under truck bed.
You can see here how the two support pillars are sitting just inside of the wheel well.
Finished product from 2 hours of work.
Lights sit pefectly over the top of the truck.
Old 07-29-2012, 11:35 PM
Crobber's Avatar
Rep:26
Forgot to take a final picture of the support pillars pulled out a bit to sit better on the wheel wells. but its an ok fit.
Old 07-30-2012, 12:37 AM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: sport
Rep:23
Dodge Boy13 is on a distinguished road
love the look im hopin i can pick one up for my 98
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
Old 05-14-2013, 05:05 PM
01dodgeramit2500 01dodgeramit2500 is offline
Vehicle: 2001 dodge ram 2500
Color: patriot blue
01dodgeramit2500 is on a distinguished road
Hi crobber do you know what the name of roll bars you have on your truck. How much did the roll bars cost.
