Neutral safety switch issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-26-2012, 06:35 PM
01ram121 01ram121 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Silver
Color: Blue
01ram121 is on a distinguished road
Default Neutral safety switch issue
Hey got an 01 ram 1500 and I believe I need to replace the nss. Truck doesn't make a sound when I try to start it. But it does start in neutral so I figured I need to change the switch. I think it's the one just above the tranny lip it's 3 wires... Green purple and black... Is this it?? If so it runs really far uP and feels like it splits so it makes me feel like I'm wrong.. Any help in locating it and trying to remove it... Thanks for the help
Old 07-26-2012, 10:29 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Its the one on the lower left front edge of trans just above pan. Also have you tryed to move shift lever a bit to see if it will start in park. Linkage might be out of ajustment.
Old 08-03-2012, 06:35 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Trim Level: Laramie SLT
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
It could be dirty inside, or a bad connection.
I had a problem kind of like this, and before I even tried to clean it or anything, I went and purchased a whole new switch. Of course once I got home I cleaned the old one and it worked just find then.
I have two now, but I would check that before you get a new one.
