Old 07-26-2012, 08:17 PM
Brandon8387 Brandon8387 is offline
Vehicle: 1996 ram 2500 cummins
Trim Level: Slt
Color: Blue
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Brandon8387 is on a distinguished road
Default Turning 5.7 into 6.4
So I'm wOndering if
1. Do all modern hemis share the same block
2. If it is possible to swap 5.7 heads out for the 6.4's
If heard people briefly talk about these swaps but I wanna know if it is really possible
My truck is a 2012 hemi crew cab 5.7 2wd
Old 07-26-2012, 08:19 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
http://www.ramforumz.com/showthread.php?t=117812
2005 Dodge NSRT-4
Old 07-26-2012, 11:04 PM
I push the skinny pedal
Rep:3277
The downside to having a 2012 is your computer. You'd have to get a hold of one of the big builders and see if they can do a 2010 swap for you.
As for the physical/mechanical side, you can easily pick up a 392cu stroker kit. There are definately quality levels among kits and spending the money will get you a higher quality kit that should stand up to more abuse.
The blocks are not the same, there is a bore difference between the 5.7L/6.1L/6.4L(?) block, however, the heads can be interchanged even though the quench area is different. The 6.1L heads bolt to the 5.7L block quite nicely but you need to look at where you want your power since the heads flow better at different rpms. I know the 6.4L heads can bolt on, but I'm not sure what the compression ratio would be.
Kurtis
Old 07-27-2012, 09:26 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Im 100% pos that the only differences in the top end is the push rod length and that some of the lifters are MDS depending on the transmissions, along with the springs and valve size of course... So as long as you dont change out the cam you should be fine. But do swap out the cam for IE: a 6.4 cam you would also need 6.4 pushrods so you will get the full bennifit of the cam...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 07-27-2012, 09:29 AM
RamTex's Avatar
Color: Stone White
Rep:366
Oh and i love how the title of this thread has nothing to do with turning a 5.7 into a 6.4 ROFLMAO!!!
