Rebuilding my 46RE . Need advice - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-27-2012, 03:23 PM
Battering Ram's Avatar
Battering Ram Battering Ram is offline
Vehicle: 2001 Dodge Ram 1500
Rep:24
Battering Ram is on a distinguished road
Default Rebuilding my 46RE . Need advice
Hello everyone. I am planning on rebuilding my 46RE/A518 transmission. From what I have looked up on the forums these were the parts(listed below) that seem to be good replacements. Can you guys think of anything else I should have done or not to do when having my transmission rebuilt?
Thanks
Tim
Kolene Steels
Red Eagle Clutches
Carbon Fiber Flex Band
Sonnax Performance Servos, covers, HD Intermediatede Band Strut
Stage 2TransGo Shift Kit or Sonnax Sure Cure
Manual valve that allows fluid charge in park???
Power Wedge Intermediate Band Anchor
Mega Spring for overdrive direct clutch
5 Clutch drum
Trans Cooler
Cooler Check Valve Delete
2600RPM Lockup Converter PATC
Borg Warner Heavy Duty Pressure Solenoid
Possibly Front 5 Pinion Planetary or just use 4 pinion?
Riding high in my Ram!
Old 07-28-2012, 09:23 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:273
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
When I had work done on mine recently it was sugested to replace the shift solenoid while it was open.
Old 08-06-2012, 10:23 PM
Rep:24
Okay I will add that to the bin of rebuild parts. Thanks
