Old 07-27-2012, 06:44 PM
99dodge360 99dodge360 is offline
Vehicle: 1999 dodge ram 1500
99dodge360 is on a distinguished road
Default crazy idle/ drop in power
So the other day I went through some water at the farm and when I went to drive home the truck started to back fire like crazy. So i limped the truck home, so once I got there I had a check engine light on pulled the codes misfire on cylinder 2 and 4. I pulled the plugs looks like there wernt firing so I pulled all the plugs and wires and also the cap. The cap looked good so I went ahead and replaced all the plugs and wires. Well after about 2 days the truck when cold would drive fine but once it got warm it would have a crazy idle like it was starving for fuel and almost like a misfire yet no check engine codes, at times it would almost stall out. Also the crossover tube for the fuel rails had a slit in it somehow so I replaced it with rubber line. Is there anything that I am missing am at a lost here all the wires were set in the correct order and plugs gapped to 40. I have included a vid also.
99 360, Spectre Cold Air Intake, Hughes Intake 52mm TB, Electric fan, 180 Tstar, IAC relocate.
Old 07-27-2012, 07:08 PM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
I had a s dime blazer that I wheeled the hell out of. it would sputter and stall the whole ride home, I blasted wd-40 under the cap and it cleared up. I know you replaced alot on it already, but is there anychance you still have moisture in the cap?
Old 07-27-2012, 07:18 PM
That was my first thought so i pulled the cap and cleaned it out I starting to think even though I set the firing order correct I didn't line up the pointer to the correct cylinder
Old 07-28-2012, 06:23 PM
Color: silver
was that the problem? all good now?
Old 07-29-2012, 10:36 PM
No after picking up a book it seems the dodge doesn't do the timing like the old Chevys. Turned out to be a bad coil weird but hey all seems to be working now
