Door hinge grinding - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-28-2012, 02:11 PM
wascobi wascobi is offline
Vehicle: 2010 Ram quad cab
Trim Level: sport
Rep:24
wascobi is on a distinguished road
Default Door hinge grinding
the lower hinge on my drivers door grinds something fierce. its starting to get a little rust on the wheel and detent arm. Ive lubed it with white lithium grease several times and it only lasts a day or two. the dealer says they have to replace the hinge to fix it. not looking forward to that. any others have this issue? my warranty is up in 5k, and even though i reported it while still under warranty, they said they wont fix it after 60k. sounds like horseshit to me. when I bought the truck and the goldseal extended warranty, I was told that it extended all coverage to 100k for everything. now they are backing down from that claim. starting to sound like all I did was prepay for overpriced oil changes.
Old 07-29-2012, 09:34 PM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
I've had similar things happen on several vehicles & all because the door was too heavy for the hinges. Simple fix -- get a piece of 2"x4" & a hydraulic jack, then placing the piece of wood @ the bottom of the door, gently jack it up -- and I do mean gently. You'll have to trial & error a few times to see how far you need to go, but that little trick has worked on every vehicle I've used it on & usually I didn't have to do it again for 2 or 3 years.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 07-30-2012, 07:37 AM
Bruce E's Avatar
Bruce E Bruce E is offline
Vehicle: 2013 Ram Longhorn Crew Cab
Trim Level: Longhorn
Rep:55
Bruce E will become famous soon enough
I had the same problem but used white grease on the hinges and it, seemed to do the trickand that was two months ago.
Vararam Cai, ARE Cap, 35" Dick Cepek Mud Country, DC-2 Wheels, Diablo Trinity.
Old 07-30-2012, 09:08 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Whenever mine starts squeaking(every few months) I spray it down with dish soap/water (degreaser) to clean it then spray it with some sort of oil to lubricate it. Seems like it lasts longer every time I do it.
Sean
Old 07-31-2012, 08:13 AM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
The creaking/groaning door issue is very common. I notice it more on my rear doors on my quad cab. Not sure if it's because those doors get opened a lot less often than my drivers door.
The tip about cleaning the hinges with a degreaser, dry, then relube with white lithium grease is excellent advice. You want to remove the old grease/crud/dirt before putting down a fresh coat of grease.
Darin
