Old 07-28-2012, 05:29 PM
derrik52 derrik52 is offline
Vehicle: dode 1997 ram 1500
Color: red
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
derrik52 is on a distinguished road
Default low idle 300rpm
my 97 dodge ram 4x4 with the 5.2l has a constant idle at 300 rpm.
i cant finda a vacuum leak and replaced the iac. when i replaced the iac and started it up for the first time the idle jumped up to 1500 and slowly started dropping then just went back to 300rpm. i cant figure it out and could use some help. thanks
Old 07-28-2012, 05:36 PM
Arth's Avatar
Arth Arth is online now
Vehicle: 2010 Ram 2500 Crew Cab 4x4
Rep:2008
Have you tried cleaning out the throttle body and making sure your idler control value isn't sticking? Just something simple to check.
Also assuming you don't have a check engine light on or any codes.
See my old Mod thread and it's Journey here
Current Mod thread here
Old 07-28-2012, 05:45 PM
Warlock III's Avatar
Thinks sheep are stupid
Vehicle: 1995 Ram 1500
Rep:1734
Send a message via AIM to Warlock III Send a message via Yahoo to Warlock III
Any codes for the O2 sensor?
Rated "D" for disturbing. Some images and language may be disturbing for some members. Crude language, sarcasm and images throughout. Not intended for all viewers
DISCLAIMER
If you are offended easily don't click on my screen name
Old 07-28-2012, 06:49 PM
Color: red
i do have a code p0443 for a purge solenoid but i replaced it and my vapor canister and the code still pops so i guessing thats an electrical issue not sure though but that is my only code
Old 07-28-2012, 08:12 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Check for a plenum leak. Lots of threads and info about it.
Old 08-09-2012, 03:26 PM
308ram 308ram is offline
Vehicle: 1996 dodge ram 1500
Color: red
308ram is on a distinguished road
This might sound dumb but i had a real similar problem and i cleaned and check throttle body but turned out a new set of battery clamps was my problem i know it doesnt make sense but it worked
