Old 07-29-2012, 02:41 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
Default old gas question
the car i bought has been sitting for 2 years and of course so has the gas i know gas goes bad pretty fast but is there a way to be able to run it, i tried removing it but the way the the hose goes down to the tank is so bendy it just keeps getting stuck and i dont what to drop the tank to remove it
Old 07-29-2012, 04:19 PM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
how much gas was left in it? u could try dumping a bottle of dry gas in the tank and than some fresh gas after it if there wasn't too much old gas sitting in it.
Old 07-29-2012, 05:40 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
Exactly.
and use premium fuel to counteract the crappy stuff.
Old 07-29-2012, 06:32 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'm not sure about that one, but can you disconnect the fuel line, add a piece of hose, and let the pump pump it out?
Old 07-29-2012, 06:46 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
I have to do this on boats quite a bit. I connect to the pick-up on the tank and use a small 12 volt ignition-protected fuel pump. They are pretty cheap (about $25) at NAPA or other parts stores. ** Also work great for removing left over gas from your mower in the fall and your snow blower in the spring!**
Old 07-29-2012, 07:04 PM
Vehicle: 95
Rep:1776
Yep, it's an alternative and I do it all the time.
Old 07-29-2012, 11:21 PM
Vehicle: Jeep GC WK
Rep:964
thanks for all of the help guys
Old 07-30-2012, 12:33 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Get as much out as possible. You could also disconnect the fuel line after the pump(assuming newer car with electric pump) and hook a hose to that outlet from the pump and run the pump to push all the fuel out. Just be careful not to run it too long and burn up the pump. A bottle of dry gas and new fuel as stated above afterwards.
Sean
