Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 07-30-2012, 01:19 AM
scott in salt lake scott in salt lake is offline
Vehicle: 2005 Ram 1500 Quad SLT 4x4
scott in salt lake is on a distinguished road
Question towing a 27' prowler 2702BS
Planning a vacation to Missouri with my 2005 Ram 1500 with 3:55 gears.
My salesman LIED and told me I had an 8600 pound tow capacity but after I bought the camper I found out I had the 3:55s and only rated for 7600 lbs because of that I only have a 13,000 lbs CGVW. My trailer is 6550 lbs dry and if I add Truck base of 5261 lbs plus 800 lbs people and the trailer I'm maxed. I have an Equal-izer hitch with sway control. I'm considering Firestone air bags. I drive heavy semi's every day so I'm used to going up mountains at 20-25 mph I don't have a problem with being patient.
I just bought the truck in Dec. I'm looking for a 2500 or 3500 cummins but I found rust spots on my doors today and am nervous about getting another Dodge.
Does anyone have any advise? How do I know a good brake controller from a bad one?
Old 07-30-2012, 03:34 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Even if you had the 3.92 or 4.10 gears, your at the weight where a 2500 is a better choice. I pull 7000lbs of trailer with my 1500 all the time, and with a few things in the box of the truck, I run very near the GCVWR. Although the truck does great, I will likely go with a 2500 (again) with my next truck so I don't have to monitor my weights so closely.
For a brake controller, go with a 'proportional/progressive' unit. They are so much better then the 'time ramped' controllers.
brad
Interested in one of my mods?
Old 12-31-2012, 02:29 PM
beginningjockey's Avatar
beginningjockey beginningjockey is offline
Vehicle: 1996 Dodge Ram F1500HD Custom
Trim Level: SLT Laramie Custom
Rep:22
beginningjockey is on a distinguished road
Yes, get the proportional/progressive units. They might be more expensive but once adjusted properly, they are VERY smooth. They are a MUST for towing any sort of heavy loads.
2016 Ram 3500HD, DRW, CCLB, 6.7 Cummins, the notorious 68RFE, 4WD, etc, etc.
2005 Nissan 350z
