Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 09-20-2012, 02:47 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Originally Posted by KarateManAZ View Post
I'm running the Yoko's staggered 275/55 up front 305/50 in the back.
I'm either going to copy your staggered sizing or just go with 285/50-20s at all 4 corners. I guess it depends on how bad I wanna have the option to rotate them vs never having to.
Old 09-20-2012, 03:53 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
With that kind of go juice, you will probably want to rotate...often!
Old 09-20-2012, 04:08 PM
CHVYKLR's Avatar
Rep:252
I'm leaning towards the staggered. More traction plus I'd rather just replace the rear tires once a year then have to rotate them all the time.
Old 09-20-2012, 04:28 PM
916Timmy's Avatar
Rep:1443
That is the other option!
Old 09-20-2012, 04:30 PM
I push the skinny pedal
Rep:3277
I'm looking at a staggered set for next summer's road tires for the same reason. Let us know what you go with, tire talk never gets old when you're trying to put power to the ground.
Kurtis
Old 09-20-2012, 04:55 PM
916Timmy's Avatar
Rep:1443
I still like the 305/45-18 option in NT555R
I just wish Ram had some 18" wheel options like Ford & Chevy
Old 09-20-2012, 07:08 PM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
Yeah man the big meats in the back are nice. I mean we can still break em loose just not a easy
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
Old 09-20-2012, 11:03 PM
HEMI450HP HEMI450HP is offline
Vehicle: 2010 Dodge Ram 2500
Rep:69
HEMI450HP will become famous soon enough
305/50/20's look mean out back. That's a wide, meaty tire that fills the wheelwell nicely with a 2/4 drop. I put the same combo on my brothers 03 ram. 305/50's out back and 275/55's up front.
Old 09-20-2012, 11:47 PM
916Timmy's Avatar
Rep:1443
I wish I didn't have 20x8's or I would run a 295/45 or the 305
Old 09-21-2012, 06:50 AM
WarBaby's Avatar
WarBaby WarBaby is offline
Vehicle: 2014 5.7 Ram 1500 RCSB/2WD
Rep:43
WarBaby is on a distinguished road
If you want to run 305/45R18's on the rear and need more traction than the 555's provide, Nitto has the NT05R in the same size but softer compound. Both are 28.9" diameter and 12" wide. I run the 555's on 9" rims with 17's up front (see signature). The combination works very well on the street and, although I haven't been on a track with them yet, when properly warmed, they hook for me (at 30 psi) during street launches when I pull the fuse for traction control and torque management. At normal psi, if not warmed, they spin hard though. http://www.nittotire.com/Tire/nt05r#size
If it's not broken, fix it till it is!
