Old 07-30-2012, 10:43 PM
my95ram my95ram is offline
Vehicle: 1995 dodge ram 1500
Trim Level: n/a
Color: red
my95ram is on a distinguished road
Default just turns over
i replaced my transmission in my 95 ram 1500 5.9L and now it wont start just turns over....i was told that it could be my crank sensor but then i was told that if i have a distributer i wont have a crank sensor ????? is this true or not ?
Old 07-30-2012, 10:55 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Sounds silly to me. Almost like someone bumped his head. Yes it still has one.
Old 07-30-2012, 11:25 PM
Trim Level: n/a
Color: red
thats what i thought also.. so does crank sensor sound right ???? or could it be something else ?
Old 07-30-2012, 11:50 PM
Vehicle: 95
Rep:1776
I'd check the wiring on the crank sensor and then pull it if necessary. I usually pull 'em before I do a trans swap so it's not too far fetched that it may have gotten damaged.
I'm sure that if you did the trans you noticed the little squares on the flywheel. For lack of a better term the sensor picks them up like Morse code and works with the dist to sent spark/timing to the cylinders. dot dot dash...
Make sure nothing got pinched in the bell housing and check it for spark while cranking it.
Old 07-31-2012, 10:04 PM
Trim Level: n/a
Color: red
thank you for your help...i'll let you know how i make out
