perplexed by ac - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-31-2012, 10:04 AM
gearbo gearbo is offline
Vehicle: 1994 ram 1500 pickup
Color: green
gearbo is on a distinguished road
Default perplexed by ac
Hi there fellow ram owners,and this is my first attempt at asking for assistance on this website so here goes. I had a evaporator leak under the dash ,so as you guessed it required taking apart the dreaded "self destructing dash", and after removing the airbox,taking it apart and replacing the evaporator and replacing all of the foam,cleaning tobacco residue off everything, I reassembled it and changed all "o" rings ,reassembled it and charged up the system,the low side line Ices up the evaporator drips liquid from the drain line,but NO COLD AIR IN THE CAB ? Any suggestions would be greatly welcomed.
Old 07-31-2012, 10:10 AM
Color: green
I also changed the orifice tube
Old 07-31-2012, 11:32 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The problem you're describing sounds like a circulating issue.
I'd check the condenser for blockage. Evac the system and disconnect the condenser and blow some air through it. Vac the system until it reaches -27 to -30. Hold it for a about 20 minutes.
