Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-01-2012, 02:10 PM
sthompson sthompson is offline
Vehicle: 2005 Ram 1500 Hemi 5.7
Color: ? brownish gray
sthompson is on a distinguished road
Unhappy Fan Blade
Anyone know of a good place to get a 7-blade engine radiator fan blade??
My 05 Ram 1500 5.7 Hemi was running hot when pulling a 5th wheel camper. After checking out the fan clutch and found it was not working right, I replaced it. That cured the problem, mostly. On these real hot days it will still go over normal, I thought I'd try a 7-blade fan to replace the 5-blade and get a better air flow. The radiator has been flushed and new cooliant put in, radiator fins cleaned out, new thermostat about a year ago.
Anyone with any exoerience with 7-blade fans??
Old 08-07-2012, 12:56 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Summit Racing has severe duty fan clutches. Is the temp going pass 210?
Old 08-07-2012, 11:11 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You sure all the air is out of the cooling system? And you don't have too much antifreeze in the mix?(antifreeze will not dissipate heat away, it will retain it, so you want a 50/50 mix with water). Just throwing that out there, don't know about the fan...
Sean
