Old 08-01-2012, 11:41 PM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
Default Tire inflation for towing with Michelin LTX275/65R20
Change P Goodyear tires to LTX275/65R20 E rated tirefor towing.
What tire pressure should I use? I'm towing at max capacity
Old 08-02-2012, 12:36 AM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
I think the max pressure on those tires as I have the same but don't tow is in the early 40's.
Old 08-02-2012, 06:51 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
What tire pressure should I use? I'm towing at max capacity.
Read the rating on the tire sidewall & go with the maximum pressure listed. l always run the max in the front tires, but not in the rear unless I've got a heavy load -- if the center of the tread is wearing faster than the edges the pressure is too high -- if the edges wear faster it's too low.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 08-02-2012, 07:09 AM
Boubou's Avatar
Rep:54
I have the factory rims on truck. Would that be too much pressure for the rims?
2010 Ram CQ SLT 4x4 Hemi with 20"
Old 08-02-2012, 07:38 AM
Rep:57
No it wouldn't be -- wheels, tires, suspension, etc. capacities are all figured into the design of the truck before the 1st one of that model was ever built.
Old 08-02-2012, 08:09 AM
Boubou's Avatar
Rep:54
Maximum pressure is 80 psi for 3800 lbs
I have Have 1710 on each front tire and 2140 on back
tire
