Old 08-05-2012, 09:55 AM
CaptJon CaptJon is offline
Vehicle: 2012 Ram 1500
Rep:41
CaptJon is on a distinguished road
The dealer might be a putz but they can check to see if a code is being thrown. Might actually save some time.
Old 08-05-2012, 10:16 AM
keystone183 keystone183 is offline
Vehicle: 2011 Ram
Trim Level: Outdoorsman
Rep:58
keystone183 will become famous soon enough
Originally Posted by xsdbs View Post
What are you plugging into the radio USB connector? It won't play an iPod if this is what you were using. It's for playing & downloading music and pictu
res to the radio HD. It ha snothing to do wit the Uconnect module which is an external module which is located to the right of the glovebox opening. Drop the glovebox down toward the floor, look inside the opening to the right. You'll see a module about 4"x6".
If the USB doesn't play a flashdrive, then I may say you have a radio related issue.
Yeah, usb drive. It doesn't recognize that anything is there when you plug it in.
Gonna check the connectors on the uconnect module today. Will keep you posted with results.
Old 08-05-2012, 01:25 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
If you can't get the USB flash drive to work (and it's formatted to FAT32), then I'd say more than likely there is an issue with the radio. Uconnect won't keep the radio from operating correctly.
