Old 08-02-2012, 07:50 PM
Zagzoo71 Zagzoo71 is offline
Trim Level: Ram 1500
Zagzoo71 is on a distinguished road
Default Converting a SC from 08 to a 10 4.7
Since there are not a lot of options (none) for a supercharger for a 2010 ram 1500 4.7 engine. Isn't the 08 and the 2010 basically the same engine? Would I be able to use a supercharger for a 08 4.7 on a 2010 4.7?
THanks
Old 08-03-2012, 03:08 AM
Jchaney579 Jchaney579 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Rep:34
Jchaney579 is on a distinguished road
THanks
Somebody can correct me if I am wrong but I am almost 100% sure the 4.7 from 10 is a completely different monster than the 08s. In 09 I think they went into it and completely redesigned it to produce more HP. Because the 4.7 in 10 is pulling almost the same hp to the wheels as the 08 5.7 Hemis were. They are called half hemis :P... So no I do not think they can be interchanged.
Old 08-03-2012, 08:10 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
The 08's were when they redesigned...but...
there are still some differences. What those are I am not entirely sure but you can bet sensors and probably exhaust manifolds too. The 08's put out the same HP/Tq as the 09's, but the 09's have WAYYYYYY more computer/gadgetry stuff.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 08-03-2012, 08:52 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
2008 was the redesign for the 4.7L. All 2008 and newer 4.7L's are the same. The only real difference with the 2008's vs that 2009+ is that it was in a 3rd gen ram, not a 4th gen ram. So I'd guess the clutch fan might be different, MAYBE slight differences with the PCV and breather system, and MAYBE some minor differences with vacuum line routing, etc., and MAYBE the exhaust manifolds, but I doubt that. The wiring harness, fuel lines, etc. are probably a little different around the engine bay but all the sensors and what not should be the same, just configured a little different. Should be 99% identical.
Where did you find a SC for an 08 4.7L?????????
MORE INFO!!!!!
Sean
