Old 08-13-2012, 10:04 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The sway bar bushings are the two bushings on the front sway bar. The sway bar links are on each end of it and are about 6 inches long and about as big around as your pinkie.
The ball joints are the joints that your front spindles (the part your rims/tires/and brake components are on) One on top one on bottom (upper and lower ball joints)
The tie rod ends are the ends that hook up to the spindles on each side that push/pull the spindle to make it move/turn. Those are the outer tie rod ends. The inner tie rod ends look just like them...but they're on the inner end.
