Old 08-03-2012, 11:18 PM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
ok. so for the 1998-2001 ram models the gauge light sizes are 5 of the pc194 twist lock bulbs. 5 are for the actual gauges. there are also 2 of the pc 194 that function as the blinkers. the high beam light is the t1.5 twist lock bulb. not what the website says. all other warning lights are the t1.5 twist lock bulbs. but there are some warning lights that are leds and are soldered to the instrument cluster. dont try to remove these ever! i used WLED-xHP10-DAC for the dome light. i used WLED-xHP15-T for the map lights. it was simple. i did have to move one of them in order to get it to light because of the direction, but it was really easy. all in all i think it took about 10-15 minuites.
all my leds came from superbrightleds.com. pm me if you need any extra help doing this on your own truck. and good luck .
these links are the 3 different bulbs for the dome, map, and instrument lights. in that order.
http://www.superbrightleds.com/cgi-b...ED-xHP10-D.htm
http://www.superbrightleds.com/cgi-b...ED-xHP15-T.htm
http://www.superbrightleds.com/cgi-b...FWLED-xHP5.htm
and this is the vehicle bulb finder. http://www.superbrightleds.com/vehic...stem/15/846/42
I'm back from the dead!
R.I.P Old Blue 2013
Old 08-03-2012, 11:21 PM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: sport
Rep:23
Dodge Boy13 is on a distinguished road
wow haha ill definatly look into it my dash is coming apart so the headunit can go in so ill scope it out
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
Old 08-04-2012, 12:45 AM
Trim Level: TRX
Rep:37
good luck with the stereo install. the instrument cluster is easy to remove. its phillips screws to remove. but the panel under the cluster where i have my light bars installed on have to come off to remove the shift cable. its really easy to undo. you twist it and it slides off. youd understand if you saw it.
R.I.P Old Blue 2013
Old 08-04-2012, 08:42 AM
Trim Level: sport
Rep:23
yeah well see there on the side for now cause theres a ton of other stuff that i gotta get done before the meet in 2 weeks haha
My Build Thread!!
Old 08-06-2012, 01:40 PM
MadSoul87's Avatar
Color: Blue/Silver
Rep:36
That blue lighting on the interior looks awesome man. Really like that. Been wanting to do the blue lighting conversion for my panel for a while now and seeing how good it looks I think it may be getting done sometime sooner than originally planned. Reps for that mod!
My Build Page
Old 08-06-2012, 03:56 PM
Trim Level: TRX
Rep:37
thanks man! next ive got hids to install, but i have to go up to my familys shop when they arent too busy. they have all the tools i need. and more experience with them.
R.I.P Old Blue 2013
Old 08-06-2012, 04:00 PM
MadSoul87's Avatar
Color: Blue/Silver
Rep:36
There ya go. HID's are always good to have. Will be doing a complete HID conversion on my rig once I get the chance/funds to do so.
My Build Page
Old 08-07-2012, 02:01 AM
Trim Level: TRX
Rep:37
what wattage are you going for?
R.I.P Old Blue 2013
Old 08-07-2012, 02:31 AM
MadSoul87's Avatar
Color: Blue/Silver
Rep:36
more than likely the 8k's
My Build Page
Old 08-07-2012, 05:32 AM
Vehicle: N/A
Rep:1045
nice interior man! im also working on converting mine. ive already done the HVAC and headlight switched, and then the gauges are next on my list. well done!
defiantly some reps for sure!
whats next on the list?
