Pyroboy5000's mod thread - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-07-2012, 02:11 PM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:47
Pyroboy5000 is on a distinguished road
Originally Posted by MadSoul87 View Post
more than likely the 8k's
thats the colr of the hids. im talking about the wattage. i bought 55w 10,000k and next up is to install them and make sure the housings hold up.
Confederate Ram TRX
Old 08-07-2012, 02:13 PM
Vehicle: N/A
Rep:1045
are you planning on separating the highs and lows with the hid kit? I can forsee issues with the headlights wiring design giving low voltage to the projector when you kick on high beam, the low will probably shut off completely.
Old 08-07-2012, 02:20 PM
Trim Level: TRX
Rep:47
the high and low beam are seperate as is. my lows go off when my highs go on. i also have a relay harness if i run into problems.
Confederate Ram TRX
Old 08-07-2012, 02:25 PM
Vehicle: N/A
Rep:1045
yea I know they are seperate, I mean the wiring splits and controls high and low. I'm worried you might have issues with that wiring creating problems for the hids.
Old 08-07-2012, 02:39 PM
Trim Level: TRX
Rep:47
ok. well what would you recommend doing if i run into problems?
Confederate Ram TRX
Old 08-07-2012, 03:25 PM
Vehicle: N/A
Rep:1045
splice off the high beam into a separate switch. that way your projector has full power all the time for the hid, and when you need extra lighting, kick on the high beam, so your running highs and lows. I did a diagram for another member for these style headlights
http://www.ramforumz.com/showpost.ph...9&postcount=34
I actually am getting a set of these this year and that's exactly how ill wire em up.
Old 08-07-2012, 03:34 PM
Trim Level: TRX
Rep:47
you should get the halo fog lights like i have that fit in your bumper as well. that would be cool as well.
Confederate Ram TRX
Old 08-07-2012, 03:38 PM
Vehicle: N/A
Rep:1045
I'm thinking of the 3g halo fogs for sure! when I get the funds together for the headlights, your gunna see some cool custom headlights. I have a pretty sweet idea in my head
Old 08-07-2012, 03:54 PM
Trim Level: TRX
Rep:47
its going to be sweet once you get it all together.
Confederate Ram TRX
Old 08-07-2012, 04:33 PM
Vehicle: N/A
Rep:1045
I'm thinking to bake em apart, black the high beam, turn signal, led and reflectors out basically everything other than the projector. that's all ill say for now.... can't give away all my secrets haha
