Old 08-03-2012, 09:44 PM
JohnDeerekid's Avatar
JohnDeerekid JohnDeerekid is offline
Vehicle: 2001 Dodge Ram1500
Trim Level: SLT Laramie
Color: Green w/ silver rockers
JohnDeerekid is on a distinguished road
Exclamation Please respond as SOON as possible!!!
Hey guys and gals,
I am currently working on replacing my timing chain, cover, and water pump. I ordered parts and found out they are for a 5.2l after I had removed most of them. Since I have a 5.9l it turns out... I was wondering if the 5.2l cover would fit. I already back tracked the timing chain/sprocket set and that is compatible. I need to know about the cover!! Also does anyone know how to separate the crank pulley from the harmonic balancer. And while on that note. How to separate the fan clutch from the water pump pulley. It is not a bolt on pulley. It is a press on. Please respond as soon as possible if you can. The Truck is basically apart.
Thanks,
JohnDeerekid
2001 Dodge Ram 1500 5.9L SLT Laramie 116,600 miles
"She Doesn't leak oil, sweats Horse Power!!"
Old 08-03-2012, 10:07 PM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: sport
Rep:23
Dodge Boy13 is on a distinguished road
i dont think they will im not 100 percent but i dont think they will
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
Old 08-03-2012, 10:41 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Be right back......
Old 08-03-2012, 10:44 PM
Vehicle: 95
Rep:1776
Believe it or not the 3.9, the 5.2, and the 5.9 are interchangeable on the timing cover. I'm going to post this and then edit so you can read this while I'm editing
The fan is screwed onto the water pump Remove one of the 13mm bolts and put a screwdriver through the hole to keep it from spinning. Get a 1 1/4 open end wrench (I think) and spin it off TOWARDS the passenger's side (reverse thread). If you have the shroud off stick a piece of cardboard in there to protect the radiator.
Lastly. The 4 bolts hold the crank pulley to the harmonic balancer tap it with a hammer and watch it fall off. The balancer is held in by the big bolt in the middle and you'll need a harmonic balancer puller to get that off (cheap $20.00).
Anything else?
Old 08-03-2012, 10:56 PM
300MAG 300MAG is offline
Vehicle: 2011 Ram 1500
Color: Deep Cherry Red
Rep:23
300MAG is on a distinguished road
Should be the same cover for 01 1500 5.2 and 5.9
Old 08-04-2012, 11:34 PM
Hey guys and gals thanks for the quick responses, like "Warlock III" said, the parts worked out and I put the parts on the engine, and it runs. YAY!!! Tomorrow I am just going to double check for leaks. o.0 lol. Once again thank you all for the help!!!
-JohnDeerekid
Old 08-04-2012, 11:44 PM
Vehicle: 95
Rep:1776
Did you get the fan off without any problems?
And the crank pulley?
