Old 08-05-2012, 02:32 PM
Jayzsun's Avatar
Jayzsun Jayzsun is offline
Vehicle: 2012 Dodge Ram crew cab.
Trim Level: st
Jayzsun is on a distinguished road
Default Timing retard
Hi!Anyone knows how i can retard the timing for nitrous application on my 2012
5.7 Dodge ram?If it's not doable can i use 114 octane fuel with one or two
Step colder plugs to prevent a desaster?I want to go between 100-125 shot.Thanks in advance...or retard....failed joke....
She thinks my Dodge is sexy!
Old 08-05-2012, 05:29 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
100-125 shot is pretty safe with colder plugs and highest octane gas...no way to retard yet..
Old 08-05-2012, 06:18 PM
1500V10's Avatar
1500V10 1500V10 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Color: true blue pearl
1500V10 is on a distinguished road
I run a 125 dry shot on my 2012 ram with stock plugs and 93 octane with no problems
2012 RCSB 2wd Ram express, 12.81@107
Old 08-05-2012, 06:37 PM
Jayzsun's Avatar
Trim Level: st
125 dry shot with no problem?So a 125 wet shot should be safer i think.And what about two step colder plugs?Are they going to be good for daily driving?
Old 08-08-2012, 12:21 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Try it with the stock plugs first. No sense changing 16 plugs on a guesstimate. Especially if it works on 1500V10's ride... Look at his sig, I think he has a pretty good idea what he is doing. Please lmk how it turns out, I may put a wet system on mine later on. Remember to pull the plugs and read them after a some usage to see what effects the nitrous has. No sense in race fuel either if you can't tune for it.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 08-08-2012, 01:11 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'd run one step colder for the plugs, and run 93 octane. That should be pretty safe for your application. Wet is safer. Higher octane is sort of like retarding timing, as it burns slower.
Sean
Old 09-19-2013, 12:11 AM
Crazyasscraka Crazyasscraka is offline
Vehicle: 1996 Dodge Ram 1500
Color: Green
Crazyasscraka is on a distinguished road
Default 1996 Dodge Ram 1500
Hello my name is Michael and i recently purchased my 1996 Dodge Ram 1500 4x4 with the 5.9l but its the heavy duty 1500 from what i was told. long story short i have 94k original miles and got it from the origional owner for $1000. i have since added a cool air intake and changed all fluids to royal purple and glass pack exhaust. i was told i can adjust timing for best performance however i dont know which way and how much to adjust it. any ideas or info would be great. Thanks
Old 09-19-2013, 09:42 AM
chefred112's Avatar
Rep:656
I run a step colder plug all the time (ngk 4306) on my daily driver with 244k miles on it..
Old 09-19-2013, 09:45 AM
chefred112's Avatar
Rep:656
I would find a way to datalog first to see whether it's runnin rich or lean to determine whether an adjustment should be made...
Old 09-19-2013, 05:59 PM
blue beast's Avatar
blue beast blue beast is offline
Vehicle: 2011 dodge ram
Trim Level: express
Color: blue
blue beast is on a distinguished road
I run one step colder ngk 7787 and mix 110 race gas. I spray a 175 shot with no problems.
