Old 08-18-2012, 10:25 PM
slowhand's Avatar
slowhand slowhand is offline
Vehicle: 2006 Ram 1500
slowhand is on a distinguished road
Default coil springs
Is there a differance of which end is the top or bottom? thanks
Old 08-19-2012, 03:57 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
If the springs are "progressive", yes, if not, no.
"Progressive" springs are wound so that the spring rate gets higher as the springs compress & you can see that when the spring is just sitting on the workbench on even installed on the vehicle with no additional load -- the distance between the coils is less & less towards one end. If that's the case then the springs need to be installed the way the manufacturer intended, usually with the closer-wound coils to the top. But if there's no difference in the spacing between the coils & you've got constant-rate springs, then it doesn't matter which way the springs are installed.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 08-19-2012, 06:44 PM
slowhand's Avatar
kewl, thanks for the info
