Old 08-06-2012, 04:52 PM
Firehawk's Avatar
Firehawk Firehawk is offline
Vehicle: 2011 Dodge Ram
Trim Level: Express RCSB/2WD
Color: Mineral Gray Metallic
Firehawk is on a distinguished road
Send a message via Yahoo to Firehawk
Question 4.56 gears available for 2WD Ram Express Hemi
Above are a few related threads I found related to 4.10 & 4.56 gear installations.. but I found a set of 4.56 gears from randy's ring & pinion (google YG C10.5-456).. Does anyone know anything about this kit and/or know if there are any other aftermarket 4.56 gear applications available for a 2WD 2011 Ram Express HEMI?
YG C9.25-456 $367.68
High performance Yukon Ring & Pinion gear set for Chrylser Dodge Ram 9.25", 4.56 ratio
I have a 2011 2WD Express with stock 3.55 gears but really don't want to have to grind/modify any stock drivetrain parts on a new truck...
http://www.ramforumz.com/showthread.php?t=101077
http://www.ramforumz.com/showthread.php?t=114813&highlight=4.56
http://www.ramforumz.com/showthread.php?p=808874#post808874
↑↑↑↑↑↑ My truck modifications list is located in my forum profile. → → →
Old 08-06-2012, 05:16 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
That part is for 10.5". You rear axle is 9.25"
Old 08-06-2012, 06:50 PM
Jchaney579 Jchaney579 is offline
Vehicle: 2012 Ram 1500
Trim Level: Lone Star
Rep:34
Jchaney579 is on a distinguished road
Bingo*^ There are kits that's for sure! All I know about it is 4.56s you have to modify your carrier for a new bolt pattern. Other than that and it being able to be done on a 2wd that is as far as I can get. LOL
If you want better gear ratio go find some R/T rear end gears. They are 4.10s and can be fit right in our rear ends since it is basically the same truck :P 4.10s are what I want for a very good mix of race/everyday city driving. I have 3.55s as well. :P
I said "Fit right in our rear ends"
Old 08-06-2012, 08:53 PM
Ram Tuned Ram Tuned is offline
Vehicle: 2012 1500 Reg. ST
Color: True Blue Pearl
Rep:16
Ram Tuned is on a distinguished road
Default 4.56 heaven
I ordered mine with 3.92s and the suregrip,barely had it a month and a real challenge to keep it tamed,I can just imagine what 4.56s would be like,whew,,,get the r/t 4.10 gears,they'll slide right in,don't know about the computer effect,maybe someone else can enlighten us about the programming.
Old 08-06-2012, 09:32 PM
Rep:34
They should be able to do it at the dealership. I know there is no tuning but changing for tire sizes and gear ratios can be done easily at the dealership or I think there are hand helds you can buy for it.
Old 08-06-2012, 11:27 PM
Firehawk's Avatar
Must have pasted the wrong one, summit sells the YG C9.25-456
3.55 4.10 4.10 4.56 ratio, gear installation oem, ram express hemi 2wd
