Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 08-07-2012, 08:21 PM
grog grog is offline
Vehicle: 2011 Ram 1500
Trim Level: Outdoorsman
Rep:17
grog is on a distinguished road
Default Oil over filled?
I had my oil changed at the dealer last week and im in the middle of a long trip so i checked it today, the oil level is above the hash marks all the way up to and on that top bump on the dipstick. This seems to be over filled, should i do something about this or is it no big deal?
Old 08-07-2012, 08:35 PM
Grubrunner's Avatar
Rep:3883
Not sure how much excess oil has been added, but a worst case scenario.....
Foaming, excess pressure on seals, induced air, possible O2 sensor damage and abnormal [excessive] emissions are a serious concern.
I would seriously drain out the excess ASAP.
Grub out!
Old 08-07-2012, 08:53 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Overfilling of engine oil fluid is always bad practice for it doesn't allow room to breathe and will have to go somewhere like say up into your crankcase breather hose which goes back into your airbox tube back into your throttle body and makes a mess in fuel delivery all together. And shame on that lube tech at your dealership. If you want it done asap, then I would simply throw a drain pan underneath your truck and unscrew the oil drain plug until you get right to the last couple of threads (be CAREFUL if it's still HOT) and then pull out for a couple seconds and then put it back in. Man did that just sound like a sexual inuendo? Damn mechanics and their tools! Hahaha! Now it's going to get a little messy but with a little bit of determination, you'll get that fresh oil back to the proper level. But make sure you have a good hold on that drain plug while you let out a little oil otherwise you might let out too much and have to refill a bit. Or you can just take it back to the dealer where the tech will be embarassed of the come back and probably mess something else up.
Old 08-07-2012, 09:08 PM
Rep:17
Well thanks, cant say this makes me feel much better seeing as i did 800miles of highway driving today and there is no dealer here and i have no convienient place to do this. ****ing dealers.
Old 08-07-2012, 09:18 PM
Rep:17
Anyone know what size bolt head the plug is?
Old 08-07-2012, 10:00 PM
hortence222222's Avatar
hortence222222 hortence222222 is offline
Vehicle: 2011 Ram
hortence222222 is on a distinguished road
13 mm and torque to 25 ft lbs....
Old 08-08-2012, 04:08 PM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
Yet another reason why I still change my own oil.
Old 08-08-2012, 04:40 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
me too, at least if I screw something up, I've only myself to blame
Exco
Bill
Old 08-08-2012, 05:41 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Depending on how much it's over filled it's not a big deal. If you drove 800 miles and noticed no problems it's fine. I would still correct it, but I wouldn't do it at a rest stop. I didn't really understand your description, but the low to high marks are roughly say 1" apart, if you're 1/4" above full it's not really a concern. If you're another 1" above full that's a lot of extra oil and will probably push past the piston rings and get burnt up. Again, not a huge concern but puts some extra pressure in the crankcase(hence the concern in the manual for the seals/gaskets) and if there's too much oil getting into the exhaust can damage the O2 sensors(again, hence the warning). The good news is it won't REALLY harm anything. The crankcase is vented and it'd be really unlucky of you to damage a seal/gasket, and worst case scenario you damage an O2 sensor(no mechanical engine damage)...
Sean
