Hesitation and stalling - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 08-08-2012, 03:32 PM
konamtb konamtb is offline
Vehicle: 1998 Dodge 1500
konamtb is on a distinguished road
Default Hesitation and stalling
I changed my plenum gasket. After putting it all back together it worked great. Turned it off, took it for a drive the next day and after about 2km it started running rough at a red light and almost stalled. After that it started jumping between 200rpms up to 900rpms when stopped and occasionally almost stalling if I didn't give it some gas. What does this sound like?
While driving it runs better but some hesitation in the acceleration when you give it gas
Before changing the gasket the truck ran extremely steady, just a little sluggish up hills, hence the replaced gasket
Old 08-08-2012, 11:08 PM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
Did you fuel up after the install? Could be just as simple as some bad gas or a loose cap. I know w my 04 if I don't shut my truck off when I fuel up it'll run rough for the first 1/4 tank or so. There was also a station that I went to that I later found out had water in there fuel and I would stall at low idle after fueling up there.
Old 08-09-2012, 03:50 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
May just need some run time to re-learn things. The computer has been adjusting for a worsening vacuum leak in the plenum gasket that suddenly doesn't exist. On the other hand the gasket could be leaking again.
Old 08-10-2012, 08:58 PM
macez's Avatar
macez macez is offline
Vehicle: 1998 dodge ram 1500
Trim Level: st
macez is on a distinguished road
is it throwing any codes
Old 08-13-2012, 10:11 PM
Irishpride413's Avatar
Irishpride413 Irishpride413 is offline
Vehicle: 1997 dodge ram 1500
Trim Level: Base model 1500
Rep:22
Irishpride413 is on a distinguished road
mine did the same thing, i swapped out my idle air control and throttle position sensor, and wala thing ran like a top
