Old 08-08-2012, 06:39 PM
lil302 lil302 is offline
Vehicle: 2001 Dodge Ram 2wd
lil302 is on a distinguished road
Default transmission help please
Ok I have a 2001 Ram 1500 2wd that I wanna swap the trans, I just bought the truck and when accelerating it will not shift into 2nd without letting off the gas, and when it does shift it seems like it slipping. Anyways I got another trans with the with the truck.
Problem I am having or am wondering is will it work. The trans in the truck has 064-1 on the bellhousing... Spare trans has 064-7 they look the same except one big sensor or plug on the drivers side tail shaft, the one in the truck doesn't have it but the spare does.
Will this trans swap in and work correct
Old 08-08-2012, 08:31 PM
Anyone? This is my daily driver need to get it working correct asap
Old 08-08-2012, 08:55 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I think...but not sure that you may have one trans that's an RE and one that's an RH.
(46RE, 46RH) I don't know what you'll have to do but that might be enough to help you out in looking. I believe the replacement trans you have is the RE.
Sorry I couldn't offer more.
I'm also pretty sure the sensor/hole is for the speed sensor.
Old 08-08-2012, 11:21 PM
Ok thanks I've been trying to look I can't find side pics of both the compare, all I know is the spare has a big white sensor plug way at the end of the trans, and the converter is a lockup bc the sticker says right on it. I hope I figure it out before the one in the truck pukes.
Trans I'd number on the spare is pk521184262542 3363
And in the truck pk52119945AA 0970 6576
Old 08-09-2012, 06:40 PM
Anyone?
Also wondering if I could maybe just swap tail housings
Old 08-09-2012, 08:54 PM
Ok so that back sensor plug seems to be a 3 prone plug with what looks to be a speedo gear?
Old 08-09-2012, 09:05 PM
Vehicle: 95
Rep:1776
I've just swapped out the tail shafts on different manufacturers in the same situation probably 8-10 times without a problem. If all the other plugs and sensors are the same I'd do it in a minute.
Old 08-09-2012, 09:46 PM
Or could I just throw the trans in and not plug in that big plug? I separated the tail housing and scarey enough a metal ring dropped loose so hopefully I got it back together right?
